Old 02-16-2023, 06:58 AM   #1
Casual Driver
Exclamation Coolant Leak - Passenger Side
Hello everyone, finally got round to making an account here
I'll get straight to my issue; I have a problem with my 2004 Boxster S 986 3.2 regarding a coolant leak. Occasionally coolant will leak into the passenger side in the cockpit. It seems to seep out from the middle part of the car (I have attached an image). I'm not sure if this has anything to do with the heater core. However, occasionally my windscreen tends to condensate quite a lot too and I'm not sure if this is related. My drainage tubes seem to be clear so that doesn't seem to be the issue causing my condensation.
I'd appreciate any help with this. Thank you all!
Image of leak;
jamesmartin986 is offline   Reply With Quote
Tags
boxster 986 , condensation , coolant leak , issue
