Old 05-25-2022, 01:23 PM   #1
gear shift recenter
2001 Boxster S 6 speed transmission
I have been searching all over the forums trying to find a confirmed fix for a gear shift issue. The issue is the shifter doesn't return to center. It goes into each gear with no problem but doesn't spring back to center as it should once taken out of gear. I have read that the detent spring is likely the problem but haven't seen anyone report back that replacing the spring solves the issue. If anyone has changed this spring and solved a similar problem I would appreciate a response or if you had to do something else to solve the issue. Thanks to all
Supercar dreams on dollar menu budget
Outkasted is offline   Reply With Quote
Old 05-25-2022, 01:30 PM   #2
1998 Boxster Owner
There is an alignment tool thingy that you can get
Benitom is offline   Reply With Quote
Old 05-25-2022, 05:23 PM   #3
Alignment tool thingy for? Care to elaborate.
Old 05-25-2022, 07:31 PM   #4
1998 Boxster Owner
https://www.ebay.com/itm/324018791966
5 speed shifter alignment tool
Old 05-26-2022, 02:25 PM   #5
I actually found one of those things inside my center console when I removed it. I'm 99% sure Stuttgart put it there so it may be worth looking before you go buy one.
Sent from my SM-G970U1 using Tapatalk
Old 05-26-2022, 05:16 PM   #6
https://www.google.com/search?q=porsche+986+6+speed+alingment+tool&oq=porsche+986+6+speed+alingment+tool&aqs=chrome..69i57j33i10i160l2.24342j0j7&sourceid=chrome&ie=UTF-8
Works for 5 or 6 speed.
Disconnect your shift cables, install tool and align the shifter. Reconnect shifter cables.
