					Originally Posted by  Outkasted
				2001 Boxster S 6 speed transmission
I have been searching all over the forums trying to find a confirmed fix for a gear shift issue. The issue is the shifter doesn't return to center. It goes into each gear with no problem but doesn't spring back to center as it should once taken out of gear. I have read that the detent spring is likely the problem but haven't seen anyone report back that replacing the spring solves the issue. If anyone has changed this spring and solved a similar problem I would appreciate a response or if you had to do something else to solve the issue. Thanks to all
There is an alignment tool thingy that you can get
