Old 08-23-2021, 05:55 AM   #1
Airbag light
When the airbag light is on, does that just indicate that a fault has been detected or does it also indicate the the entire system is disabled?
Old 08-23-2021, 07:15 AM   #2
Ike,
My understanding is that if you get an airbag light the entire system will be disabled.
Airbags are explosive devices. So when there is an issue the system is disabled due to potential liability issues.
Old 08-23-2021, 08:16 AM   #3
That's what I figured too, but an "all or nothing" system seems like a liability in and of itself.
Old 08-23-2021, 09:37 AM   #4
Not quite correct; it depends upon why the light is on (which code). For example, if the deceleration sensor or control module is offline, everything is disabled; if just one air bag circuit is disconnected or shorted, only that air bag is offline. Systems also vary by model year, later ones being more sophisticated than the earlier ones.
Old 08-23-2021, 09:44 AM   #5
Thanks for the clarification.!
Old 08-23-2021, 11:17 AM   #6
That makes more sense, thank you!
