Old 08-02-2021, 07:08 AM   #1
gabedrummin's Avatar
Checking timming
In an effort to rule out an out of time motor ,I am going to attempt to check and adjust the timing with the motor in the car . I have bought a cam timing aliment tool . If I need to re-adjust timing , am I supposed to remove the tenisoner's and if so all or which one ? I read my vacuum gauge wrong and my motor is producing low vacuum the gauge says late timing . So I am assuming timing is off . I also bought an injector to put into cylinder 4 that has the miss .Injector should be here by weeks end . Thanks fr all your help .
Old 08-02-2021, 01:22 PM   #2
you dont remove the tensioner when doing the timing.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
