-   -   Checking timming (http://986forum.com/forums/boxster-general-discussions/81209-checking-timming.html)
gabedrummin 08-02-2021 07:08 AM
Checking timming
In an effort to rule out an out of time motor ,I am going to attempt to check and adjust the timing with the motor in the car . I have bought a cam timing aliment tool . If I need to re-adjust timing , am I supposed to remove the tenisoner's and if so all or which one ? I read my vacuum gauge wrong and my motor is producing low vacuum the gauge says late timing . So I am assuming timing is off . I also bought an injector to put into cylinder 4 that has the miss .Injector should be here by weeks end . Thanks fr all your help .
Stl-986 08-02-2021 01:22 PM
you dont remove the tensioner when doing the timing.
