Old 06-17-2021, 07:18 AM   #1
I really need help as I'm losing the will to live with this car, the roof has been broken for a while and I was told the specialist left it in "manual operation" but it doesn't manually operate!!! They told me that you need someone each end to pull the clamshell up as its too stiff, I've had an issue because the garage for an unrelated job needed to get to something and the roof will not operate! Is there anything I can check for? I dont understand how if they have disconnected everything the roof can still not be operated manually. I can't sink anymore money into this pit so I'm not going to get it fixed If it is above my pay grade, cheers
Corey Hill is offline   Reply With Quote
Old 06-17-2021, 08:03 AM   #2
When converting to manual operation, I've seen guys put trunk latches to hold down the clamshell. Maybe look for a release cable tucked behind/beside the driver's seat.
Old 06-17-2021, 09:36 AM   #3
contact the "specialist" who left it in manual operation and find out exactly what they did instead of fixing the issue.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 06-17-2021, 01:58 PM   #4
Yeah sore subject really, they have a massive following and great reviews but they damaged the front end of my car and eventually agreed to pay but not had any communication since
Old 06-17-2021, 02:03 PM   #5
well then I would let their massive following know and provide honest review
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 06-17-2021, 05:57 PM   #6
78F350's Avatar
This may be helpful if you work on your own car now: Stuck Convertible Top - Manual operation...
Later tonight I'll re-post the old video I had about converting to manual in case it's helpful, but I expect there are plenty of others on YouTube by now.
Old 06-17-2021, 06:51 PM   #7
78F350's Avatar
Here's the video I made a few years ago when I had a top stuck. It shows how I converted it to manual operation. The shop that worked on yours may have left the links to the clamshell connected.
Old 06-18-2021, 12:59 PM   #8
That video is super helpful. Thanks!
David Preston
2008 Cayman S
por356c is offline   Reply With Quote
Old 06-18-2021, 01:27 PM   #9
I`m not sure if that helps, but if the mechanism is still intact you can operate the motors by bypassing specific connections using two wires after removing the control unit. This is how I operate my top until I get a new control unit. Obviously if they disconnected everything this won`t work but since you are not sure perhaps it`s worth a shot. These pins need to be shorted: 25-22; 27-23 for closing, 27-22; 25-23 for opening.
Homeoboxter is online now   Reply With Quote
Old 06-19-2021, 05:56 PM   #10
Any chance the shop disconnected the pivot arms for the top but not the clamshell? When I had mine disconnected, the clamshell was easily raised by one person.
