Thread: Help
Old 06-17-2021, 09:03 AM   #2
ike84
Originally Posted by Corey Hill View Post
I really need help as I'm losing the will to live with this car, the roof has been broken for a while and I was told the specialist left it in "manual operation" but it doesn't manually operate!!! They told me that you need someone each end to pull the clamshell up as its too stiff, I've had an issue because the garage for an unrelated job needed to get to something and the roof will not operate! Is there anything I can check for? I dont understand how if they have disconnected everything the roof can still not be operated manually. I can't sink anymore money into this pit so I'm not going to get it fixed If it is above my pay grade, cheers
When converting to manual operation, I've seen guys put trunk latches to hold down the clamshell. Maybe look for a release cable tucked behind/beside the driver's seat.
Sent from my POCOPHONE F1 using Tapatalk
