Old 06-03-2021, 11:47 AM   #1
KevinH1990's Avatar
Originally Posted by Johnny5 View Post
I believe the shifter you are referring to that’s shorter is what’s on the gt2 and gt3 if I’m not mistaken. I know the 987 / 997 is for sure is better then stock but just wondering if it’s better to just get the short shifter kits rather then stock
I think it is a matter of personal preference. The best way to decide would be to check out all of the options in person and decide which meets your expectations. I picked the 987/997 shifter because:
1. I found one available for about $130
2. I didn't have to destroy my shifter to install it
3. Several people on the forums spoke highly of it
4. As a bonus, I was able to sell my OEM 986 shifter to someone else for $50 so that they could use it as a base for installing an aftermarket short shifter.
The 987/997 OEM short shifters were in the $300 price range and that was more than I wanted to spend. At a net cost of $80 I think I got my money's worth. Since I was painting my center console and replacing the parking brake switch at the same time, the extra labor was negligible. I concede that there are likely to be better options. If I ever run across an inexpensive OEM 987/997 short shifter, I expect I would buy it and install it.
I once drove a Honda S2000 back-to-back with my Boxster and I found the S2000 shifter to be much better than the Boxster. I think the S2000 shifter is superior to the shifter on the Miata I previously owned. The Boxster and the Carrera need longer shift linkages than the S2000 or the Miata. I expect that engineering a good shifter is more challenging in a mid or rear engine car than in a car with a front engine and the transmission located below the driver's right hand. Try driving a 914 sometime. The shifters in the 914s I've driven have been very loose and I found it difficult to determine whether I was in gear or which gear I was in.
Old 06-03-2021, 01:43 PM   #2
CrisZenithBlue's Avatar
I second the S2000 shifter comment, having owned one and driving a Miata. The S2000 prob has the best stock shifter on the market, nice throws, notchy and precise, prob the best feature of that car. But yes, it sits on top of the transmission so we'll never be able to match that in our cable linkage cars.
Im not sure about the exact differences between Ben's shifter and the ebay one but having tried both I can tell you his feels better. Its still a very economical option and it works great!
He actually designed a new tall shifter that brings the shifter right next to the wheel, I have one of those and will install it in a few days. That might be the sweet spot for me as I feel I have to reach down to shift. Again, living in the past, in the S2000 the shifter sits closer to the wheel because the center console is very tall, and its just a much smaller car overall. With this new tall version it will come up and be close to wheel.
CrisZenithBlue is offline   Reply With Quote
Old 06-03-2021, 04:40 PM   #3
I decided to stick with Ben's. Though to be fair, I had the 997 shifter in my car for 5 years and was perfectly happy with it. I think you'd be happy with either over the stock shifter. Depends on what you can find a deal on and how inclined you are to modify a stock shifter to use Ben's. As Kevin pointed out, if you go the 997 route you can sell your stock one to offset the cost, which is what I did when I originally purchased mine.
I ended up getting a deal on Ben's shifter already installed into a factory cradle from a generous forum member here, so for me it was an easy swap. It's definitely shorter and tighter feeling than the 997 unit. But like I said, both are a nice upgrade from stock, especially if your current shifter has some miles on it.
Old 06-11-2021, 08:17 AM   #4
So Im going to try to have everything buttoned up on a 2.5L engine and while I have things open wanted to get some advice on things I should upgrade internally? Ive read somewhere that the 987 oil return separator in the sump was beneficial? Can anyone confirm?
Johnny 5 is offline   Reply With Quote
