Old 06-03-2021, 11:47 AM   #1
KevinH1990
KevinH1990's Avatar
Originally Posted by Johnny5 View Post
I believe the shifter you are referring to that’s shorter is what’s on the gt2 and gt3 if I’m not mistaken. I know the 987 / 997 is for sure is better then stock but just wondering if it’s better to just get the short shifter kits rather then stock
I think it is a matter of personal preference. The best way to decide would be to check out all of the options in person and decide which meets your expectations. I picked the 987/997 shifter because:
1. I found one available for about $130
2. I didn't have to destroy my shifter to install it
3. Several people on the forums spoke highly of it
4. As a bonus, I was able to sell my OEM 986 shifter to someone else for $50 so that they could use it as a base for installing an aftermarket short shifter.
The 987/997 OEM short shifters were in the $300 price range and that was more than I wanted to spend. At a net cost of $80 I think I got my money's worth. Since I was painting my center console and replacing the parking brake switch at the same time, the extra labor was negligible. I concede that there are likely to be better options. If I ever run across an inexpensive OEM 987/997 short shifter, I expect I would buy it and install it.
I once drove a Honda S2000 back-to-back with my Boxster and I found the S2000 shifter to be much better than the Boxster. I think the S2000 shifter is superior to the shifter on the Miata I previously owned. The Boxster and the Carrera need longer shift linkages than the S2000 or the Miata. I expect that engineering a good shifter is more challenging in a mid or rear engine car than in a car with a front engine and the transmission located below the driver's right hand. Try driving a 914 sometime. The shifters in the 914s I've driven have been very loose and I found it difficult to determine whether I was in gear or which gear I was in.
