Old 03-01-2021, 06:50 AM   #1
Door Connector Pins
I am working on adding OEM door speakers to my base car which had only dash speakers. I have a new door panel, the speakers and the proper door harness. I could bypass the door connector and run the wires separately, but since I have the harness, and since I broke the upper retaining clip when I removed the door connector, I am thinking of replacing the door connector on the body side and adding the new wires to the backside. Does anyone know what pins are used in the door connector? I would need to add the 4 new ones for speaker and courtesy light.
Zibodo is offline   Reply With Quote
Old 03-01-2021, 12:12 PM   #2
WALDMEISTER
BRAN's Avatar
I don't remember anymore, but you can check, how I did it:
BRAN's - 986 - Seal Gray Anatomy
Old 03-01-2021, 04:21 PM   #3
OK I admit it I'm a nutcase. I looked at how you did it and that seems to be the standard-to route around the connectors with separate wiring. I could do that and just cut the connectors off the door harnesses I have. But before I go that route, I wanted to explore using the original connectors as intended. If I can just figure out the appropriate pins, I can insert them in the empty sockets and the the door harnesses will be usable as is.If anyone knows how to identify the pins I would be interested
