Old 03-01-2021, 04:21 PM   #3
Zibodo
OK I admit it I'm a nutcase. I looked at how you did it and that seems to be the standard-to route around the connectors with separate wiring. I could do that and just cut the connectors off the door harnesses I have. But before I go that route, I wanted to explore using the original connectors as intended. If I can just figure out the appropriate pins, I can insert them in the empty sockets and the the door harnesses will be usable as is.If anyone knows how to identify the pins I would be interested
Zibodo is offline   Reply With Quote
