02-21-2021, 06:07 PM
Lost key, replacement options?
So I lost my keys 5 days ago and have finally decided that they're gone. Called the local porsche dealership and they quoted $400 for the key and then $150 to pair it to my car, and that's not even considering towing fees (not even sure if my car can be towed where it is + the parking brake is up and it's 1st gear) I'd love any insight ya'll would have into the situation as I'm pretty young and this is my first car and have never dealt with anything like this, much less with porsche. Thank y'all in advance
02-21-2021, 06:51 PM
If you have no keys, you don't have a lot of options
In addition to getting the key physically cut, it has to be programmed to the car, and that requires not only a Porsche PWIS, but the security codes that can only be gotten from a dealer.
What you were quoted is pretty much inline with other Porsche dealers. The $150 programming is a little high, but not unusual
02-22-2021, 06:51 AM
1998 Boxster Silver/Red
Welcome to the forum. Maybe ask the dealer if they'll cut you a deal for two keys.
Oh, the word Porsche is CAPITALIZED.
1998 Porsche Boxster
02-22-2021, 07:47 AM
OUCH!!
Good idea to get 2 keys at the same time
02-22-2021, 07:52 AM
Correct me if I’m wrong, but isn’t there a cheaper key option that does not have any buttons that could just be used to manually lock/unlock the door?
I totally understand the key still needs to be cut and programmed, but would cut the cost of the key down as $400 seems steep.
02-22-2021, 08:03 AM
It can be safely flat bedded; they will put wheel dollies under each wheel to allow it to roll up onto the flat bed to get it to the dealer you choose.
You might be able to find a cheaper key somewhere, but the car cannot be coded to accept it without the Ipass codes that come from the dealer and the PIWIS diagnostic tool to do the coding. If you want to get this done, just bite the bullet and pay the dealer's price.
02-22-2021, 11:35 AM
A couple years ago, after receiving oxygen and recovering from getting the price of a new remote key at my local dealer!!
I purchased 2 spare basic keys that have just the light and no locking buttons.
Part # 996-637-041-01 and #996-583-531-00 Only $138.50 for the pair.
The dealer programed them for an additional $88.50
I find inserting the key and turning the lock is not that difficult. I do have to open the door to release the frunk and trunk.
1998 Boxster
1991 Carrera
02-22-2021, 12:25 PM
A remote key also activates the security and alarm system
02-22-2021, 02:25 PM
Maybe it varies with the model year, but my basic keys activate and deactivate the alarm system when I lock or unlock the door.
1998 Boxster
1991 Carrera
02-24-2021, 10:42 AM
Are those able to turn on the car?
02-24-2021, 10:45 AM
Yes, they do everything the remote key does just no buttons.
Manually lock / unlock the door, set and shut off the alarm, Raise and lower windows, start and stop the engine.
1998 Boxster
1991 Carrera
Reason: adding details
02-24-2021, 11:09 AM
Here's a photo of the basic key.
1998 Boxster
1991 Carrera
03-01-2021, 02:49 PM
Maybe the ECU Doctor could help. Send them your ecu and immobilizer?
Just a thought, maybe a reach.
03-01-2021, 07:22 PM
not exactly, it doesn't remote lock/unlock the doors or open the trunk or frunk
06-05-2021, 03:10 PM
I lost my keys and bought new key fob for 150 from a Porsche dealer here in Los Angeles sun coast Porsche has the fobs for about the same price I have a copy of my key I will just need to get it programmed asap I don't really want to tow it to a dealer and a few auto locksmiths I called don't to Porsche
06-05-2021, 06:59 PM
Unless you have the small white paper tag with the Ipass coding numbers on it, no one can code the car with a new key, not even a dealer.
06-06-2021, 11:23 AM
There are 2 basic security features built into our keys.
The first is a pill that when energized send a signal to the dme. This is what is responsible for disabling the immobilizer. It's the same technology in nearly every "key with a chip" (hint hint)
The second is the remote transmitter. It works similar to garage door openers, it communicated to the immobilizer through a set of rolling codes. In order for it to be programmed, you must (as jfp said) have the iPas code (comes with the key) and a piwis to enter that code into the dme system along with your immobilizer codes (which can be obtained by politely asking from most Porsche dealerships). You will occasionally see these keys with codes for sale on EBay. They're never cheap, but they're less expensive than what the dealer charges for them.
So, in short, you can buy a basic key (without buttons) and have the pill cut and programmed by anyone who has that ability - you can actually buy the programming hardware in Amazon - and it will work fine in your car. If you want the clickety click buttons though you only have one choice - legit key with code and piwis tool (unless you buy a basic key and then install a 433.9mhz receiver hardwired into the central locking circuit in the center dash, but that's a different discussion)
06-06-2021, 05:18 PM
There is another approach.
Remove the pill from a working key and attach it under the ignition cylinder bezel with tie wrap, shrink wrap or glue.
Buy a plain key online and have it cut to fit the car latches and ignition switch.
Buy and install an inexpensive remote start keyless entry system from Amazon or Ebay, Search this site for "3rd party keyless entry" for detailed information.
In the end you have as many keys as you buy and fobs that work for keyless entry.
All for less than $100
Good Luck
06-08-2021, 01:06 PM
When i purchased the keyfob from the dealer it has info on the white tags that come with the key. I do not believe they will sell you a keyfob without providing the info needed or is there some other info i might be missing thats needed? my unit under the car seat has been swapped out before hope that wont be an issue i thought i read it might be an issue.
06-08-2021, 01:13 PM
There are a lot of people selling keys with either fake or totally missing Ipas tags, and you only find out the tags are bogus when you try to code the car.
