Old 02-13-2021, 01:49 PM   #1
2001 Boxster Coolant Leak
Greetings:
I recently purchased my first Porsche, a 2001 Boxster with 120k miles. Previous owner replaced IMS, RMS, water pump, clutch, spark plugs and coils very recently.
I have noticed a robust leak of pink coolant out of the overflow tank hose once the car warms up, confirmed by placing the back of the car on a ramp and observing fluid coming from the lumen of the tube. I have driven the car around 600 miles or so since purchasing, and have not noticed a "low coolant" light. There is no visible leak around the water pump, hoses, or thermostat housing.
The heater works as it should, and the car does not overheat, which leads me to believe that both the water pump and thermostat are functional. There is no white smoke from exhaust and no unusual color (white/creamy) on the oil dipstick.
There is a -04 series radiator cap installed, a dry trunk, no corrosion in the bottom of the trunk, no wet area on rug, and no corrosion around the bleeder valve bolts.
Nevertheless, I attempted to manually raise the bleeder valve with the small metal tab on top, which promptly came off in my hands. It appears that there is wear around the rubber where the metal tab sits on the bleeder valve, and I am uncertain whether this valve is working at all.
I was going to replace the radiator cap (despite being an -04) and the bleeder valve with a genuine Porsche part (around $85 or so, as the aftermarket parts have not gotten the greatest reviews).
Notably, if I remove the radiator cap while the engine is warm, I don't get the sense that there is any pressure/steam/etc. escaping from the overflow tank. I wonder if the hoses were ever removed from the tank (it doesn't look old/yellowed), and if so, were placed back on the right nozzles?
What else might I be missing? The coolant system seems to be unique on Porsches (i.e. I'm just getting used to it). I have done quite a bit of work on other cars, including Alfas, Maseratis, Cadillacs, Mercedes, etc., so I am rather handy. Before I start throwing $$$ at head gaskets, etc., was curious what others more experienced with these cars might think.
Any help appreciated.
Best
Dave
The Sandman is offline   Reply With Quote
Old 02-13-2021, 03:53 PM   #2
Before throwing parts at it the first thing to do is a system pressure test.
That should help you locate the fault.
The burp valves can be rebuilt.
Old 02-13-2021, 05:15 PM   #3
78F350's Avatar
Originally Posted by The Sandman View Post
... Nevertheless, I attempted to manually raise the bleeder valve with the small metal tab on top, which promptly came off in my hands. It appears that there is wear around the rubber where the metal tab sits on the bleeder valve, and I am uncertain whether this valve is working at all. ...
The bleeder valve tab should not come apart. There should not be visible wear on the rubber where the tab sits. It sounds like your vale is worn out/damaged and dumping coolant before it reaches normal operating pressure.
I'd watch that area when you do the pressure test.
Old 02-14-2021, 10:00 AM   #4
Attached pressure test kit to overflow tank cap with a tight seal, cold engine. System holds *no pressure*. Heard air leaking around the bleed valve. Put some water around the valve, and saw bubbles near one of the screws where bleed valve cover attaches to overflow tank. No obvious cracks and no pink fluid in trunk.
Bolts are tight so didn’t feel the need to overtighten.
Are next steps replacing the bleeder valve, o ring, etc, or ?
Dave
Old 02-14-2021, 11:59 AM   #5
78F350's Avatar
You can replace the bleeder valve. I have pulled one apart on a bad tank out of curiosity and it's not too complex. Here's a thread that I've read before: My first Question, Bleeder Valve?
I would recommend replacing the entire tank unless you know that it has been done in the last several years. The tank will wear out eventually. Why not do it now. There are lots of complaints about aftermarket tanks. Many of them are flawed right out of the box. Best to go with Porsche brand even though it costs (much) more.
The easiest way to replace the tank:
DIY Coolant Tank Replacement in Under 2 Hours
Old 02-14-2021, 12:33 PM   #6
Many thanks for the links... fingers crossed that this is the source of the problem vs. a red herring.
Any other reasons why I shouldn’t have any pressure (ie cannot even pump it up to 2-3 lbs)?
Dave
Old 02-28-2021, 08:25 AM   #7
Dave
Replaced the bleeder with a new kit. Haven’t noticed any leak from underneath car, through the overflow pipe nor is there a coolant odor anywhere. Interestingly, when the car is hot (180) or so, unscrewing the cap still releases no pressure.
Dave
Old 02-14-2021, 02:42 PM   #8
I discovered that my bleeder valve was leaking when I attempted to use a vacuum lift tool to replace the coolant in my 987.1S. I purchased a new bleeder valve kit and It was straight forward to replace. Just be careful not to over tighten the screws as they go into the plastic reservoir. I used silicone grease on the rubber seals to seat them properly.
Sent from my Pixel 3 using Tapatalk
RobT987 is offline   Reply With Quote
