Old 01-11-2021, 06:16 PM   #1
Boxster42
Camshaft plugs
I'm having a issue with my camshaft plug on the passenger side lower cam. Both plugs pop out and the oil just pours out.
Bryan1977@yahoo is offline   Reply With Quote
Old 01-11-2021, 07:24 PM   #2
You have a pressure problem in the crankcase; the plugs just press in with finger pressure, if they are popping out, you do not have a functioning AOS unit supplying case vacuum.
Old 01-12-2021, 04:55 AM   #3
Boxster42
I believed the mechanic put way to much oil. If the metal plug popped out also fo o have to have a machine shop press them back in. And if so can the lower cam be removed without taking the whole engine out
Old 01-12-2021, 07:26 AM   #4
BYprodriver's Avatar
It can but it ain't fun or easy!
Old 01-12-2021, 07:52 AM   #5
Can you elaborate a little more on what the issue is? Are you talking about the steel plug inside the camshaft? First thing I`d look at is the relief valve whether it`s stuck in the closed position. Bottom of the oil pump housing, easy access. Removing the cams is doable, just not typicallly a fun job, as Bypro said.
But if you are talking about the green plastic plug with the metal insert, you don`t need to remove anything, just press it back on and deal with pressure in the crankcase at the AOS...
Old 01-13-2021, 11:09 AM   #6
The green plugs popping out tends to be an issue after cam covers are resealed with too much RTV.
Old 01-13-2021, 12:08 PM   #7
This sounds interesting. What`s the connection?
Old 01-14-2021, 10:17 AM   #8
there is a thin passageway in the cover that acts as a vent of some type (the particulars i do not know). too much rtv plugs the passageway and you get the plugs popping out
Old 01-14-2021, 01:04 PM   #9
The permanent solution is to tap pipe threads in the cam end & screw in a pipe plug with sealant.
Old 01-14-2021, 04:42 PM   #10
Thanks, that makes sense.
