11-16-2020, 01:28 PM
#1
About to dive in on the IMS this weekend on my 2001 Boxster S - clutch is getting sticky/stiff, and ordered the full kit from our host, and found the Pelican IMS for only $199 plus the cost of the LN tools at $299. Not an LN, but since I only drive ~1500 miles/year, it seems like cheap insurance, even if it is a maintenance item down the road. I'm a capable DIY'er but admit the replacement process makes me a little nervous in getting it right. Going to do an inspection and if a double row is in there I may choose to leave it alone if the seal looks good and the bearing freewheels nicely. I'll have the replacement in hand to make the call when I get in there...
Anyone have any tips on how not to screw up the install of the IMS? I'll be following the Tech Article, but advice is always helpful!
11-16-2020, 09:06 PM
#2
Damn Yankee
Even if your engine has the dual row bearing, the Pelican IMS kit should include a spacer of some sort to make their bearing adaptable to your situation.
As far as replacement tips, make sure to put the new bearing in a freezer for a while, and heat up the receptacle to insure a relatively easy, and accurate, fit.
There are plenty of threads/videos outlining this process. Google is your friend here.
Just sayin’.......
TO
11-17-2020, 05:42 AM
#3
agfours, if you are that far in, just do it. Not that tough a job.
-H. L. Mencken
11-17-2020, 07:35 AM
#4
My advice is do not follow Pelican's Tech article. Use LNE's method. There are several threads where Pelican's method has caused a lot of grief.
11-17-2020, 10:15 AM
#5
Good to know. I've been studying sources from Pelican, YouTube and this forum, but will do a review of their method. I'm surprised there would be issues with the Tech Forum approach. I've seen folks talk about parts being in the wrong bags for Single/Dual row installs, but there is good enough photographic example in the 100+ pics to sort that out. I suspect the complexity of instructions and the amount of disparate sources of truth have been a detractor for some taking on this challenge. It certainly is a daunting amount of information. The process may take 12 hours end to end, but the research is taking just as long...
11-17-2020, 11:49 AM
#6
Pelican's IMS retrofit methodology has led to more heartaches than I can count. LN's procedure, on the other hand works perfectly if it is followed to the letter.
11-20-2020, 08:30 AM
#7
How much is a peace of mind worth? I spend $73 a year on synthetic oil changes (Mobile-1) after driving about 2K miles during the summer before winterizing. Going on 5 years of ownership, but have no plans to change/upgrade IMS.
I'm with Ciao........(and my Porsche shop experts)
I summer drive my 98' and yearly have Mobil One oil changes done. My car is 20+ years old and has 89,000 summer only miles on it and runs (and looks) perfect. But, IF I become one of the 1% that have a failure I'll say "it was tons of fun while it lasted" and then go shopping!
11-17-2020, 07:43 PM
#8
... Going to do an inspection and if a double row is in there I may choose to leave it alone if the seal looks good and the bearing freewheels nicely. ...
If you decide to leave it, an alternative is to remove the seals so the bearing will be oil lubricated. This is what I did on my blue Boxster while doing a clutch job. My reasoning is in post #9 of this thread.
My Blue Boxster refurb.
Grant
