Old 11-08-2020, 07:57 PM   #1
Vza
Debris in gas tank
Hi all, Ugh....I was putting gas in my 99 boxster from a 3 Gall can. I used a plastic turkey baster to extend the funnel I was using. Apparently the baster was not gas proof and began to break down and a piece broke and I believe fell into the tank. It was a piece of plastic the size of a pea. I assume it will dissolve and nothing will happen. The tank is half full. Any suggestions. Thanks v
Vza is offline   Reply With Quote
Old 11-09-2020, 02:58 AM   #2
1998 Boxster Silver/Red
I wouldn't sweat it. If it makes it out of the tank the filter will catch it.
1998 Porsche Boxster
Old 11-09-2020, 08:02 AM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
My take. Fill the tank full. If it is going to dissolve, the additional gas will dilute the mixture.
Old 11-09-2020, 05:51 PM   #4
Vza
That was my thought exactly....dilute with a full tank. V
Old 11-09-2020, 05:58 PM   #5
911monty's Avatar
If you're thinking of that route I'd run a test to see what happens. break a piece of the baster and put in a jar of gasoline. If it dissolves and disappears okay, but if it becomes a gelatinous blob then your injectors might not survive.
Old 11-11-2020, 08:19 PM   #6
Vza
Funny....I was planning on doing that as well. Not so funny....just had my injectors serviced! Thanks V
