Old 09-03-2020, 05:41 AM   #1
This is a common problem with the 6 speed transmission. It is caused by excessive wear of the synchromesh and also the detent being a bit weak. If you catch it early you can keep it going longer by installing an aftermarket second gear detent that holds better.
Once it starts popping out of gear when warm you have no other choice than a rebuild.
1941 Dodge Luxury Liner Coupe
Old 09-03-2020, 07:37 AM   #2
2003 S, Arctic Silver, M6
paulofto's Avatar
My 03 S has a similar issue especially when cold. I usually double clutch going into second for the first few shifts and then things clear up. Downshifting from 3 to 2 sometimes grinds if I haven’t properly rev matched but not often.
PS it is definitely the synchro confirmed by my indie. He said live with it for now or pay mucho bucks. I’ve learned to live with it.
Old 09-03-2020, 08:01 AM   #3
Servicing the gearbox with fresh OEM oil may help your synchros to work better
Old 09-04-2020, 09:44 AM   #4
BYprodriver's Avatar
Not enough for the hassel on mine.
Old 09-03-2020, 10:56 AM   #5
01 Boxster S
This happens to mine as well when cold only. First few times going into 2nd, then its fine the rest of the day
519AutoTech is offline   Reply With Quote
Old 09-04-2020, 06:22 AM   #6
husker boxster's Avatar
How tough of a job is it to change the synchro? Is it a DIY or something best left to an expert? Asking for a friend.
1989 928 S4 5 spd - black
Old 09-04-2020, 09:50 AM   #7
It requires a big press to do it right, I sent mine to California Motorsports in Arizona where they installed their modified schncro & improved detent & billet shift arrester.Now 2nd gear shifts easier than 3rd!
Old 09-06-2020, 12:29 PM   #8
9864ever's Avatar
Thanks to all that responded. I think first I will attempt to change the gear oil with OEM or a suitable aftermarket one and go from there.
9864ever is offline   Reply With Quote
Old 09-06-2020, 06:56 PM   #9
Good luck. I've recently changed mine twice since the grinding began and new fluid didn't improve things. It certainly needed changing the 1st time since it was still the original and I'd done quite a few DEs. Decided to change the 2nd time to try Motul but that didn't help either. Hasn't gotten to the point of popping out of gear and it only grinds on the 3-2 shift, so I avoid that as much as possible.
