Old 09-03-2020, 05:41 AM   #1
Anker
This is a common problem with the 6 speed transmission. It is caused by excessive wear of the synchromesh and also the detent being a bit weak. If you catch it early you can keep it going longer by installing an aftermarket second gear detent that holds better.
Once it starts popping out of gear when warm you have no other choice than a rebuild.
1941 Dodge Luxury Liner Coupe
