Old 08-17-2020, 09:49 PM   #1
Ignition switch problem - fixed!
Hello,
my car is 1998, 2.5 Boxster 986.
I had a problem with the strarter - when I put the key on contact position and turn it right to start the car the key didn't turn back left. It was staying in position, so there was a problem with the electricity - AC, radio, lights, wipers and so on were not working.
I had to turn it back mannually.
Local keysmith told me that I had to change the ignition switch. He explained me that for my Boxster this part is identical to one used in Audi 80, 1996-1999. Turns out that new ignition switch cost 20 bulgarian leva (around 12 USD) and the labour cost was 30 leva (18 USD).
I am attaching photo of the part in case anyone has same problem.
It was cheap and easy fix.
monopola is offline   Reply With Quote
Old 08-21-2020, 08:01 AM   #2
What a coincidence that you posted this two days ago and I'm having this same problem today.
So this part only pushes the key back left after you start the engine?
CaptSlow is offline   Reply With Quote
Old 08-21-2020, 02:35 PM   #3
piper6909's Avatar
It doesn't exactly "push the key back." The internals simply turn easier allowing the lock spring to return it back to the proper position. There are two types of locks on these, new style and old style. Make sure you get the correct one.
Congrats to Monopola for finding the fix and thanks for sharing!
2010 Subaru Forester
Old 08-22-2020, 05:44 AM   #4
As far as I know this part it the one that connects all electronics to the starter. Also, in it there is small metal spring that helps the key to turn back after car start. It is pretty important and my idea was to share that cheap part for another model is the same as the one for Pirsche, so you can save some money
English is not my native language, so thechnical specs are very hard for me to explain
Old 08-23-2020, 06:31 AM   #5
Rob175's Avatar
English may not be your "native language" but you explained it EXCELLENTLY!.....welcome!!
