Old 07-07-2020, 10:18 AM   #1
egx
Start problem
Hi guys,
i picked up my new to me boxster 1999 2.5L
Everything works fine, although sometimes i turn the key and electronics go off but no ignition. it's not the battery because i just lock, clutch in clutch out lock in unlock and boom everything works fine. doesnt seem to be consistent.
what can it be? ignition switch? old keys? clutch switch?
thanks!
egx is offline   Reply With Quote
Old 07-07-2020, 10:50 AM   #2
I assume that you mean that the electronics turn on when you turn the key, but the engine won't turn over.
I'd start with the clutch switch since its easy to jumper it to see if the situation improves (or easy/cheap to simply replace). If you jumper the clutch switch be sure to have the trans in neutral if its a manual 5-spd when you try to start the car!
If that doesn't help, then I'd replace the electric portion of the ignition switch (depending on your flexibility, it can be a bit of a PITA).
Old 07-07-2020, 11:56 AM   #3
egx
thanks a lot! i tried pushing harder on the clutch and changing the floor mat and helps so ill try your solution. thanks!
Old 07-07-2020, 02:52 PM   #4
Check this first
Here is a post I put up a year ago about this problem. Cant find the pictures but they are in the link.
Intermittent Start Problem
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
