Old 08-11-2017, 01:13 PM   #1
WillH's Avatar
Hard start with low fuel?
Had a search around but didn't find my answer. Why does my box not like to start with its usual ease when the tank is near empty? No problem any other time...
Thanks.
Old 08-11-2017, 01:56 PM   #2
I am No. 1348
algiorda's Avatar
Have you tried loosening the gas cap when the fuel is low?
Current: 2004 Boxster S 550 Spyder Anniversary Edition (BSSE)
algiorda is offline   Reply With Quote
Old 08-11-2017, 02:27 PM   #3
WillH's Avatar
I'll give it a try before next fill up. So tank breather/evap system issues?
Old 09-20-2017, 01:45 PM   #4
WillH's Avatar
Okay, I'm pretty sure it's not breather issues. No difference with filler and flap open before starting on near empty. I'm pretty sure I'm experiencing fuel pressure bleed-down when the fuel level is near the point when the low fuel light will come on.
Old 06-09-2020, 02:52 PM   #5
Did you ever find a resolution to this? Having a similar problem when I’m below a half tank.
torquedemand is offline   Reply With Quote
Old 06-09-2020, 03:34 PM   #6
WillH's Avatar
Nope. When it’s cold and close to the low fuel light coming on I have to crank it for a few seconds. Once warm it’s fine.
Old 06-09-2020, 07:59 PM   #7
Brian Minson's Avatar
Run a few tests, do a fuel pressure test then a fuel pump test. Here are two videos on how to do it at home.
Fuel Pressure Test: https://youtu.be/hddx5Ux1v4Y
Fuel Pump Test: https://youtu.be/wEWepuDUes4
Brian
Brian Minson is offline   Reply With Quote
Old 06-10-2020, 02:08 AM   #8
WillH's Avatar
Thanks. I’ll try to take a look this weekend if time permits.
Old 06-10-2020, 10:58 AM   #9
Another thought: The problem could be battery voltage related. Check the battery voltage at cold start vs hot start at the battery and at the starter.
Old 06-24-2020, 11:56 AM   #10
WillH's Avatar
Thanks for the response Mr Stone. Hadn’t thought of that. Absolutely no trouble from cold with anything more than about an 1/8th of a tank of fuel. Below that and it needs to crank a second or two to start.
Waiting on a package from LN to get my water pump issue out of the way. Then I’ll get back to this.
