Old 05-21-2020, 07:57 AM   #21
Rob175's Avatar
I buy HF tools but know full well they are cheap and "disposable". That's exactly what I want for a singular special use or a one time use, but as a regularly used tool there's just no way. Good tools can last several lifetimes and can be passed down but HF tools not so much.
Would I trust HF tools with my "life".....NO! But I'd also never crawl under any car while supported by ANY jack stand, but that's just "chicken" me. If I need to work under the front or rear of a car I prefer to use a set of ramps (front or rear). But that's about it.
Rob175 is online now   Reply With Quote
Old 05-22-2020, 11:32 AM   #22
I have four of the 6-ton stands that are part of the recall. I only use these for quick tire changes.
For under the car work, I use a four-post lift which has mechanical/emergency stops. Then I place tall jack stands under the lift for the just-in-case backup scenario. And I still don't like being under there!
Old 05-25-2020, 02:48 AM   #23
Subman's Avatar
There are many things worth saving money on.
Safety isn't one of them.
2004 Boxster S - 50th Anniversary of the 550 Spyder
2000 Carrera Cabriolet
2016 BMW R1200R
1971 BMW R75/5
Subman is offline   Reply With Quote
Old 05-26-2020, 11:27 PM   #24
Just buy ESCO’s and be done with it. Worth every penny, it’s not worth a 3000lb bench press attempt to go cheap.
Old 05-27-2020, 06:09 AM   #25
1998 Boxster Silver/Red
This +1.
10 characters.
1998 Porsche Boxster
Old 05-27-2020, 12:42 PM   #26
Will there be cake?
tonythetiger's Avatar
DONE...no more messing around, these are really nice and not much more expensive. I can already tell that lining them up where they wont damage the bottom of the car is better too.
Old 05-27-2020, 12:58 PM   #27
piper6909's Avatar
This +1.
10 characters.
You and I are two of them, who are the other 8?
I returned 3 pairs to HF. The guy said that the mechanism does't always catch correctly, it's not that they break. Either way, it's unsettling.
I'm liking those ESCOs with the pin. No doubting that mechanism. Does anybody know where they're made?
piper6909 is online now   Reply With Quote
Old 05-27-2020, 01:13 PM   #28
There Is No Substitute.
rick3000's Avatar
I like the Esco's a lot, and recommend them, but I do have to point out one thing about them and the 986. The lowest setting on the regular size is a bit high.
The lowest setting on the regular size is 13", they now make a shorty style where the lowest setting is 11". It's doable, but 13" pretty high for the 986 when you are lifting it one wheel at a time. Because the 986 frame is so rigid, I have had one whole side of the car in the air, with just one jack stand in the rear, which can be nerve-racking. This is why I now use 2-stage wooden cribs to get the wheels 6" or 12" off the ground before placing it on stands.
Old 05-27-2020, 09:37 PM   #29
Multi-Boxer Driver
Deserion's Avatar
From what I’ve read they were shipped off to China for production, some reviewers say the weld quality isn’t quite as good as in the past.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
