Old 04-28-2020, 05:07 AM   #1
Thanks to JFP - Trans Fluid Change
Hi guys - recently JFP advised a forum member, and all of us, this its wise to change our trans fluid every 30-40k miles instead of the Porsche 90k recommendation. I am glad I did that - the fluid in my trans (04 SE, 40k) was pretty dark. I also learned that in JFPs opinion there is absolutely no problem in drilling a hole (2.5") in the aluminum pan cover to gain access to the trans drain plug, which was easy peasy. The pan is not structural. That sure saves a lot of work, because you don't have to take off the two aluminum support bars and the pan cover. Although you have to research a bit where to cut the hole, with a 2.5" hole, you have some leeway. And, I am all set for next time!
But the real point of this note is to thank JFP for his counsel and his patience with us! We are very fortunate to have his help in our 986 community! Thanks JFP.
David Preston
2008 Cayman S
por356c is offline   Reply With Quote
Old 04-28-2020, 05:48 AM   #2
I completely agree. I believe he's the most valuable source of information on here and other forums. It also impresses that he has been doing it for so long and has the patients to answer the same questions over and over.
Woody
Old 04-28-2020, 05:57 AM   #3
husker boxster's Avatar
I've also received wise consult from him and really appreciated it. Thanks JFP.
Plus he advises on other forums too. Obviously he's able to juggle many items simultaneously.
1989 928 S4 5 spd - black
Old 04-28-2020, 07:04 AM   #4
There Is No Substitute.
rick3000's Avatar
100% Agree! He's helped me a few times over the year, so I'll say it again: Thanks JFP!
rick3000 is online now   Reply With Quote
Old 04-28-2020, 07:18 AM   #5
78F350's Avatar
Every time I'm searching for the correct, no-BS answer for something Boxster related, I use "JFP" as one of the search terms. Always gets the right answer. Thanks JFP.
Old 04-28-2020, 08:31 AM   #6
1998 Boxster Silver/Red
In addition to being very detailed, and patient, in his responses... he is very clear in his communications, telling it like it is.
Most definately he's one of my "go-to" personalities.
Thanks, JFP!
1998 Porsche Boxster
Old 04-28-2020, 08:44 AM   #7
jaykay's Avatar
Agreed recognition is well deserved
986 00S
Old 04-28-2020, 08:46 AM   #8
2003 S, Arctic Silver, M6
paulofto's Avatar
+++++++ on all the comments. JFP has always provided the right guidance.
Old 04-28-2020, 08:54 AM   #9
Agreed! JFP is a great asset to this community!
Old 04-28-2020, 09:59 AM   #10
WillH's Avatar
+1 on all the above
Old 04-28-2020, 03:57 PM   #11
911monty's Avatar
We are very fortunate to get EXPERT advice that is concise, precise, brief and to the point. AMEN to everything previously said.
Old 04-28-2020, 05:18 PM   #12
1997 Tip, 2018 Macan
rexcramer's Avatar
+1 and enough characters to make the computer happy.
Old 04-28-2020, 05:53 PM   #13
Oldcarguy's Avatar
Thanks JFP for all your help across the years, always spot on
Rgds, Fred
Old 04-28-2020, 08:44 PM   #14
April 28th is now officially JFP day!
Thanks for all you do!
98 Arena Red 986
Old 04-28-2020, 08:57 PM   #15
OMG, the man's gonna have a head the size of a beach ball.
But...I can't disagree with the sentiment. He's helped me a bunch too!
Frodo is online now   Reply With Quote
Old 04-29-2020, 11:30 AM   #16
piper6909's Avatar
I'm a relative newbie on here, but still I have to tip my hat to JFP. His depth of knowledge is a huge asset to this forum.
Old 04-29-2020, 12:18 PM   #17
A thread worth piling on. +++++++++1 to Jeff
Jgkram is offline   Reply With Quote
Old 04-29-2020, 01:38 PM   #18
BYprodriver's Avatar
Jfp
I try to read every post from JFP even if I have no interest in the thread topic he has posted in. Might need the info some day.
Old 04-29-2020, 01:49 PM   #19
No doubt. His advice has saved me more than once.
He’s a valuable resource around here.
robdelorenzo is offline   Reply With Quote
Old 04-29-2020, 09:20 PM   #20
CEL P0306
JFP rules! Thanks for your generosity to the community of us.
aczyzewski is offline   Reply With Quote
