Old 04-28-2020, 05:07 AM   #1
por356c
Thanks to JFP - Trans Fluid Change
Hi guys - recently JFP advised a forum member, and all of us, this its wise to change our trans fluid every 30-40k miles instead of the Porsche 90k recommendation. I am glad I did that - the fluid in my trans (04 SE, 40k) was pretty dark. I also learned that in JFPs opinion there is absolutely no problem in drilling a hole (2.5") in the aluminum pan cover to gain access to the trans drain plug, which was easy peasy. The pan is not structural. That sure saves a lot of work, because you don't have to take off the two aluminum support bars and the pan cover. Although you have to research a bit where to cut the hole, with a 2.5" hole, you have some leeway. And, I am all set for next time!
But the real point of this note is to thank JFP for his counsel and his patience with us! We are very fortunate to have his help in our 986 community! Thanks JFP.
David Preston
2008 Cayman S
por356c is offline   Reply With Quote
