04-23-2020, 07:51 AM
Porschephile
Brake Fluid Reservoir questions
What's the trick to removing the inner 'basket' in the reservoir without chopping it up like I have done? I use the pliers and pull method and you can see what it has done. I didn't see this as an individual part that could be replaced? Anyone?
2004 Porsche Boxster S
Portland, Maine
04-23-2020, 09:00 AM
It looks as if you've got a particularly stubborn one. They do eventually pull out...and I don't think the part is available separately. I seem to remember I pried mine off with a screwdriver...with some difficulty.
04-23-2020, 11:00 AM
Brute force and ignorance is needed
04-23-2020, 11:07 AM
Try getting a small screwdriver between the screen and neck. Then open it up enough to sneak a needle nosed pliers in. Grab with the pliers and pull it up but also in a circular motion.
1989 928 S4 5 spd - black
04-23-2020, 01:17 PM
^ what they said... especially husker though it seems to vary each time. In which case, refer back to JayG's directions. LOL
"Cool Prius!" - Nobody
04-24-2020, 08:15 AM
why do you want this out so badly?
04-24-2020, 12:51 PM
Probably to suck out the old fluid and flush with new.
04-24-2020, 05:41 PM
years ago (like 15) the 1st time i flushed the fluid I removed it without any issues. Last year the damn thing would not come out. Kind of crazy.
04-24-2020, 10:23 PM
That's why I take mine out. I use a turkey baster and remove the old fluid from the reservoir. No need pushing it thru the lines so I can bleed it off.
04-25-2020, 05:45 AM
1998 Boxster Silver/Red
Wouldn't flushing it eliminate any old fluid? Why remove the entire tank in the first place? I flushed my fluid not long ago using the Motive... removed zero, except for the reservoir cap.
Am I missing something? I'm open to instruction? Thanks!
1998 Porsche Boxster
04-25-2020, 06:48 AM
Yes, flushing would remove the old fluid in the reservoir. But the reservoir holds a fair amt of fluid. Why push all of it thru the lines to just bleed it out? By removing the screen, you can access the reservoir with a turkey baster and remove the old fluid. Replace with new fluid. Then all you have to bleed is the fluid in the lines.
04-25-2020, 08:55 AM
Thanks. Makes sense.
IIRC, when I flushed my fluid I was wondering why that part didn't just lift out and... with the baster I didn't remove much.
08-11-2021, 12:14 PM
I removed the screen easily but have no access for turkey baster. There is like another screen. Is there a way to remove it?
08-11-2021, 06:45 PM
There's only 1 screen in the reservoir. Once it's out you should have full access to the fluid. Sounds like you just took the cap off the reservoir.
Can you attach a pic?
08-12-2021, 09:34 AM
I gave up on mine... and let the whole fluid drain and refilled later on, I mean as it was going down.
I tried pliers, flat blade, fingers, nitrile gloves... nothing worked.
