Old 04-25-2020, 08:55 AM   #12
Starter986
1998 Boxster Silver/Red
Yes, flushing would remove the old fluid in the reservoir. But the reservoir holds a fair amt of fluid. Why push all of it thru the lines to just bleed it out? By removing the screen, you can access the reservoir with a turkey baster and remove the old fluid. Replace with new fluid. Then all you have to bleed is the fluid in the lines.
Thanks. Makes sense.
IIRC, when I flushed my fluid I was wondering why that part didn't just lift out and... with the baster I didn't remove much.
Thanks!
1998 Porsche Boxster
