Old 04-25-2020, 06:48 AM   #11
husker boxster
husker boxster's Avatar
Wouldn't flushing it eliminate any old fluid? Why remove the entire tank in the first place? I flushed my fluid not long ago using the Motive... removed zero, except for the reservoir cap.
Am I missing something? I'm open to instruction? Thanks!
Yes, flushing would remove the old fluid in the reservoir. But the reservoir holds a fair amt of fluid. Why push all of it thru the lines to just bleed it out? By removing the screen, you can access the reservoir with a turkey baster and remove the old fluid. Replace with new fluid. Then all you have to bleed is the fluid in the lines.
1989 928 S4 5 spd - black
