Old 10-14-2006, 10:18 PM   #1
Send a message via MSN to CJ_Boxster
Thanks, no i didnt use a template, what i did was i used white model car paint, then used a brush to paint within the reverse embossed numbers that are already present on the knob, then after its completely dry as a bone, i used a very fine grit sandpaper to sand off any excess paint that I got outside the numbers...pretty much error proof, After Im done with the sanding and im satisfied, I get some armor-all and re-moisterize the surface to bring back the gloss that you lose from sanding it... I think it looks better than stock now that i've done that.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 10-16-2006, 11:45 AM   #2
Wow! 100,000 miles? Might be the highest milleage boxsters around... on original engine? Congratulations.
GWPORSCHE is offline   Reply With Quote
Old 10-16-2006, 03:01 PM   #3
Yeah its original miles engine...If you keep up on the oil changes with good oil and try not to bounce off the rev limiter while never bogging down the engien at low rpms... i think all boxster engines should last this long. I have about 100220 miles now.
Heres the picture i took the instant it went to 100000 miles.
Carlos J Cazares
