Old 04-14-2020, 04:39 PM   #21
WillH's Avatar
When I got mine, (5speed), the cold shifting wasn’t great. Changed with Porsche oil at 60 000 miles. No improvement with shift quality when cold. No problems when warm. Still happy in knowing the oil is fresh.
Old 04-14-2020, 09:22 PM   #22
We always purchased ours directly from a dealer, that way there was no mistaking what we were using.
Thank you, I'll visit at the dealer for the oil
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
Old 04-14-2020, 10:20 PM   #23
I used Royal Purple syn oil as its supposed to be OK for the brass synchros- shifts OK as fluid that came out looked brand new :/ about 8k on the RP and no issues
aparke4 is offline   Reply With Quote
Old 04-18-2020, 06:25 PM   #24
Porsche "Purist"
Paul's Avatar
Make sure you follow the factory fill instructions, it is not fill until it overflows.
My 01 has been running Royal Purple for about 50K miles, shifts well hot or cold. In the cold the Porsche brand was a little more stiff at sub zero WI temps.
https://www.pelicanparts.com/techarticles/Boxster_Tech/38-TRANS-Manual_Fluid/38-TRANS-Manual_Fluid.htm
1987 924S. 2002 996TT. PST-2
