Old 03-23-2020, 06:26 AM   #1
Battery
Hi
My battery is dead and won't charge, in spite of it being only 2 years old.
I started the Car fine only 1.5 months ago.
Any ideas of why this had happened?
I need a new battery and was wondering if the group is suggestion of make and model to get? Im
Based in Oslo, Norway.
Regards
Morten
gabba76 is offline   Reply With Quote
Old 03-23-2020, 10:29 AM   #2
If it sat in the car for 1,5 month it´s fairly normal that it has drained without a maintainer.
If you try an old style charger without all the monitoring etc it might be able to force the battery to start charging.
Regarding a new battery, I dont really have any good suggestions.
Robert986 is offline   Reply With Quote
Old 03-23-2020, 12:38 PM   #3
Originally Posted by gabba76 View Post
Hi
Regards
Morten
Get an AGM battery, and a Ctek battery maintainer.
Old 03-23-2020, 12:41 PM   #4
Great, many thanks
Old 03-23-2020, 03:02 PM   #5
The alarm discharges the battery quite quickly.
Fuzzuki is offline   Reply With Quote
Old 03-23-2020, 03:53 PM   #6
bcrdukes's Avatar
I second this. And the LED on the factory radio, which can be disabled. I've been dealing with battery discharging every winter as I do not drive my car in the winter at all, and with no place to charge it. I've had to resort to starting it up every few days and driving it up and down the underground parking garage to ensure the battery is maintained.
2001 Porsche Boxster S
bcrdukes is offline   Reply With Quote
Old 03-24-2020, 12:49 PM   #7
pilut2's Avatar
Make sure that you are letting the car get to full operating temperature before shutting it off or else you risk internal corrosion and engine damage over the long term. It might be better to remove the battery and charge it occasionally over the winter.
1999 Boxster, Ocean Blue Metallic-grey top.
LN IMS dual row-, Ben's short shift kit
pilut2 is offline   Reply With Quote
Old 03-24-2020, 12:55 PM   #8
Ordered, collected via drive - in and installed AGM battery today. The entire process took less than 1 hour. Thank you for valuable insight into what might cause the drainage..
My car is parked in a secure garage during winter so disabeling alarm could help?
Regards
Morten
PS: I have another question with regards to an audio Upgrade. Would this improve or cause problems vis a vis battery lifetime?
Old 03-24-2020, 12:57 PM   #9
Many thanks for this, will do!
Old 03-24-2020, 01:12 PM   #10
Regards
Morten
If you have the Ctek attached, you don't need to do anything else.
Old 03-24-2020, 05:22 PM   #11
bcrdukes's Avatar
I'm not sure if you can bypass / disable the alarm. If someone knows a way, I would appreciate if the procedure is shared.
Let us know how the AGM battery goes. I may consider this if it works out.
