Old 02-09-2020, 11:07 AM   #1
Battery charger/maintainer/power supply
Hello everyone,
I want to buy a battery charger with power supply mode to be able flash ECU, maintain battery or replace battery. Looking on Amazon and some other places, I found OTC-700A which can charge/supply up to 70A or Noco G7200 that can charge at 7A and supply only 5A. Price difference is huge. OTC for CAD650 or Noco for CAD120. First is professional for industrial use and Noco is suggested for normal home garage use.
Any suggestions?
radionokiatv is offline   Reply With Quote
Old 02-12-2020, 06:30 PM   #2
Topless's Avatar
I have the NOCO and like it. I think mine is rated at 4A charging and adapts to SLA, AGM, and Li batteries. As a smart charger/maintainer it helps to keep the battery healthy.
A70A charger is only needed if you want a backup way to start the car with a dead battery. Complete overkill for basic charger/maintainer.
Old 02-13-2020, 04:33 AM   #3
1998 Boxster Silver/Red
What about this?
https://www.harborfreight.com/automatic-battery-float-charger-42292.html
1998 Porsche Boxster
Old 02-13-2020, 08:40 AM   #4
@Starter986, We don't have HF in Canada, but I got your idea. Thanks!
Old 02-13-2020, 08:43 AM   #5
@Topless,
Will the typical charger/maintainer like Noco work for ECU flash? It seems that car need to have a constant 13.8 for flashing.
Old 02-13-2020, 07:19 PM   #6
Topless's Avatar
Originally Posted by radionokiatv View Post
@Topless,
I have never done it and have no idea. What does your software vendor say? I would probably keep the battery connected and use the maintainer at the same time. Don't guess, follow the instructions from your software vendor.
Old 02-14-2020, 05:17 AM   #7
Who's askin'?
maytag's Avatar
@Topless,
Yes. The float charger I use is not much different from what you're looking at.
You don't get to sue me if you ball anything up. Haha
Old 02-14-2020, 07:29 AM   #8
I just purchased a NOCO Genius 1 and really like it. It's currently under $30 USD on Amazon right now and has separate modes for standard, AGM, and lithium batteries. YMMV.
2002 Boxster S, 6 speed, Speed Yellow
Flat Six Innovations 3.8L Stage II Track Performer, RoW M030 Suspension, B&M Short Shift Kit, Fabspeed Bypass Pipes, FVD Brombacher "Sound Version" Muffler, UD Pulley, Low Temp T-Stat.
Banana S is offline   Reply With Quote
