Old 10-30-2019, 06:26 PM   #1
Doc
Does this mean the AOS is toast?
Hi,
2001 S. Experiencing a bit of hunting idle. Took out the TB to clean it. Found oil in the intake, see pics. This points to the AOS, right?
Thanks so much!
Fluellen is offline   Reply With Quote
Old 10-30-2019, 08:29 PM   #2
Need For Speed
KRAM36's Avatar
Yes that is coming from the AOS. With that much oil you should see white smoke coming out of the exhaust when starting the engine.
2003 Boxster S
Old 10-30-2019, 09:26 PM   #3
01 Seal Gray 986 S
bg305's Avatar
I think so..
I just went something similar, details here: 2001 S idle issues / hesitation when warm
-Brian
bg305 is offline   Reply With Quote
Old 10-31-2019, 07:42 AM   #4
honestly some oil in the intake is normal on modern pcv equipped cars. That amount of oil does not appear excessive. Testing the AOS is probably a good idea anyway, but I'm not sure this fully indicative of an AOS failure
Old 10-31-2019, 10:01 AM   #5
kk2002s's Avatar
+1
Every time I have gone to clean my TB there is some oil residue. I would expect some as that is one of the functions of the AOS. Now the amount you get is subjective. If you have puddles and white smoke then AOS would be something to look at.
Seal Grey
Old 10-31-2019, 11:47 AM   #6
Sorry to jump on this thread, but how do you "test" the AOS?
1998 Porsche Boxster - Ocean Jade Metallic
1985 Porsche Carrera Targa - Guards Red
1978 Porsche 911SC Euro Non-Sunroof - Grand Prix White
Seadweller is offline   Reply With Quote
Old 10-31-2019, 12:29 PM   #7
kk2002s's Avatar
First level of no tool testing is while car is running see how hard is it to remove oil filler cap. More specifically you need a tool to measure vacuum and compare the results with the expected. Search and you will find references to the tool and the nominal values expected
Seal Grey
Old 11-02-2019, 12:32 AM   #8
Doc
Thank you for your replies.
The car does not exhibit any of the other signs of a failed AOS, so I decided to just clean the TB for now and put everything back together. The idle is very steady now, so I’ll declare victory at this point.
Thanks again!
