Old 10-01-2019, 09:27 AM   #1
Drain all the coolant again?!
My 2001 Boxster S had its engine replaced with a used engine from eBay 10,200 miles ago (17 months) at which time the coolant was entirely drained and replaced.
However, I'm hearing the water pump beginning to fail and every thing I read about it says that all the coolant must be drained when the water pump is replaced. I'm wondering, though, in this case, if it would be okay to not do that since the miles and time on the coolant is relatively low.
What are your thoughts?
cc986 is offline   Reply With Quote
Old 10-01-2019, 09:37 AM   #2
piper6909's Avatar
I believe you're safe not to flush the coolant if the vanes of the old WP are intact. I don't see any other reason why you would need to, given that the existing coolant is so new.
Old 10-01-2019, 09:37 AM   #3
to get the pump out, just about all the coolant will drain anyway. You may be able to keep about 2 gallons out of 6 in the car, especially with the ass end up.
Old 10-01-2019, 10:24 AM   #4
Porsche "Purist"
Paul's Avatar
Just drain it into a clean bucket and reuse.
1987 924S. 2002 996TT. PST-2
Old 10-01-2019, 12:19 PM   #5
Thanks, piper6909, that makes sense -- we don't want any plastic bits floating around in the pipes. I'm hoping my WP is not that far gone... I've only been hearing the 'diesel' sound (described on another thread here) and when I remove tension on the serpentine belt, I can easily make the WP pulley wobble. No obvious leaks and no issues with cooling.
Old 10-01-2019, 12:21 PM   #6
Thanks, Quadcammer -- I figured that might happen, which is ok if I don't need to drain everything, especially the radiators.
Old 10-01-2019, 12:22 PM   #7
Thanks, Paul. I'll consider this if I can find a clean enough bucket and I don't introduce any crud from the outside of the hoses, etc.
Old 10-01-2019, 02:14 PM   #8
Put a trash bag in the bucket, drain into the bag. Now you dont have to clean the bucket or worry. I keep a box of white trash bags in the garage for this reason, several jugs of empty coolant and a funnel just for coolant. Take your time filling the jugs and you shouldn't lose a drop.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 10-01-2019, 10:03 PM   #9
Yeah, I just lifted mine up high enough to get a 5 gal coolant container under mine and reused the coolant, it had just been flushed and redone a few hundred miles prior (of course). My impeller was fine, so no big deal.
Old 10-02-2019, 10:19 AM   #10
Brian Minson's Avatar
I would try and save what you can and reuse it with the new water pump.
Brian
Brian Minson is offline   Reply With Quote
Old 10-03-2019, 08:49 AM   #11
Thank you all for your input, my stress levels are definitely coming down.
Old 10-03-2019, 08:57 AM   #12
What kind of coolant should I use to top it off?
I guess the last question on this is, if I have to top it off, what kind of coolant should I use? The work order for the engine replacement listed "2 gallons of Pink G40".
I found a nearby NAPA parts store that sells "Zerex G-40 Euro Pink Antifreeze", so I think I'll go with that for any needed top-off.
Last edited by cc986; 10-03-2019 at 02:48 PM. Reason: Found a local supplier of G-40
Old 10-03-2019, 05:18 PM   #13
what is in there now? If it's green, top with green, if pink, top with pink
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 10-03-2019, 11:39 PM   #14
It’s not quite that easy. Your best bet, if you don’t know what the coolant is, is to go ahead bite the bullet, fully drain, then flush and put the Porsche stuff in. Coolant is just a pain in the ass these days with all the colors, moat, boat, oat, whatever. If you mix the wrong kinds you can wind up with a real mess inside your engine. The Porsche stuff is “pinkish” and I’m pretty sure it is a long life coolant. (Not) It comes undiluted in gallons and is only slightly more expensive than other quality coolants.
Old 10-08-2019, 11:48 AM   #15
Thanks to all for the comments and suggestions... I've driven a couple of times to work and back with the new water pump and thermostat, and -- knock on wood -- things seem to be going alright.
I did end up just collecting and reusing the drained coolant. I did filter it through a cloth, even though there were only a few particles of debris (most likely from the loosening of the hose clamps). I was able to use my torque wrench on 5 of the 7 water pump bolts, and 1 of 4 thermostat bolts. The rest were tightened by feel. Does anyone else do this, or is there a super small version of a torque wrench that can fit into and around the water pump?
Overall, I lost about a pint of coolant, which I replaced with distilled water. The whole engine sounds remarkably better with the new pump.
Thanks again!
Old 10-08-2019, 01:11 PM   #16
piper6909's Avatar
Thanks again!
Awsome!
Old 10-08-2019, 02:44 PM   #17
1998 Boxster Silver/Red
Thanks again!
Tightening by feel, if you've a handle on it (figuratively speaking) should be fine. Keep an eye out for leaks for a few miles. I was in the same position, literally, and by feel tightened all my bolts. I didn't have confidence in the small torque wrench I had, and wasn't prepared to drop the quid for confidence.
You should be fine.
1998 Porsche Boxster
Old 10-08-2019, 03:06 PM   #18
piper6909's Avatar
You should be fine.
"Quid"? Are you a Brit bloke?
