09-18-2019, 07:41 AM
#1
Racer Boy
It's common to hear some chain rattle at start-up, but that usually sounds like, well, a chain rattling briefly, not a seal bark.
I'm sure that someone else will chime in with some other ideas.
09-18-2019, 08:02 AM
#2
1998 Boxster Silver/Red
I believe you're correct. I've the same rattle, and I hate it. Just when no longer do I give a **************** about the IMS, the new worry is cam deviation values, lol.
I'm on the fence about new tensioners. The long-timers likely would say with ~125K on the clock to just drive it and shutup.
1998 Porsche Boxster
09-18-2019, 11:28 AM
#3
My chain rattle disappeared after switching to Shell Rotella T6 a few years ago.
09-18-2019, 01:21 PM
#4
I had same symptoms and pulled my starter motor, took it apart, and re-greased it. The squeal/bark disappeared. I had a normal sounding startup for awhile.
The starter squeals when the starter gets stuck and doesn't recoil fast enough into its housing after the engine starts.
Re: startup rattle - I'm beginning to think some cases of the rattle could actually be related the starter. After I greased my starter I had a normal sounding startup, but with time (6 mos) the car began rattling on cold startup - at the same conditions and for the same duration as the squeal had occurred.
My theory is that my starter is worn (original) and possibly damaged from the previous owner failing to fix the squeal. I think grease might've bought the starter more time but it is still slow to release on startup, hence the rattle. It's also possible I didn't grease it enough/use the right grease.
Edit: 2.5L
Reason: Edit: 2.5L
09-18-2019, 01:55 PM
#5
2002 2.7 Boxster in green
Edit: 2.5L
Cool thanks, ive decided just to replace it, job done then
09-18-2019, 03:45 PM
#6
I'll try that next oil change. That stuff isn't inexpensive. Less expensive than tensioners. Still.
09-18-2019, 05:52 PM
#7
PW,..what type of oil 20-50 ??
09-18-2019, 06:25 PM
#8
I don’t remember it being terrible. I bought a big 2.5 gallon/10 quart jug for $50.
Edit: just checked and Walmart still has them for $49.97...not much different than Mobil1.
09-22-2019, 07:21 PM
#9
If its chain rattle,.(.which mine does once after the 1st start) ,..why dos'nt it do it everytime you start the car if the internal parts were bad or maybe worn a little it should kinda always do it,.but if its only the 1st start should it not be the tensioner's because they have time to bleed off or maybe the oil is a little to thin..?? Its just annoying
09-22-2019, 08:45 PM
#10
Not only the tensioner's bleeding off.
But also the lifters bleeding down over time.
A little tensioner pad wear, a little chain stretch, a little this a little that and you have slack in the chains.
Start the car, oil pressure pumps everything back up. No noise tell everything bleeds down again.
| Thread Tools |
| Display Modes |
Hybrid Mode
