Old 09-07-2019, 06:45 PM   #1
Long crank starting issue
2002 Boxster S with tiptronic.
So, while I was away from work the wife reported her car started having trouble getting the car started. It went from two or three max turn overs to up to 10 second long cranks.
So upon getting home I have had 2 weeks to deal with this monster and try to learn it. We had a Cel of course and I did as much troubleshooting as i could with hours upon month time of research yet can't figure it out.
It doesn't crank weak. Strong, steady turns till it fires up. Originally we had no drivability issues but I guess overtime or my countless attempts to solve this it now idles a little weak until it jumps to 1100 rpm and settles out quickly.
Rpm band used to be strong and smooth but now we have some hesitation upon acceleration usually around 4k rpm. Even in park it sometimes doesn't allow full throttle. It's not consistant but happens too often to ignore.
It doesn't stall out or die. It only does so clearing the cel when trying to relearn its idle.
So the codes I have seen with this issue so far are:
P0442
P0410
P1411
P1128
P1130
P1126
P1133
P1125
P1132
I discovered the hose off of the aos came loose when inspecting for leaks. It came off of the intake tube side. I connected it back and made sure it was situated better.
I cleaned the MAF sensor as good as anyone could with maf cleaner. Just the cleaner. It has the latest MAF sensor ending in 125.01. MAF readings are 4.5 to 5.5 g/s.
I cleaned the throttle body and intake before and after it. Before it was pretty spotless. Behind it had slight oil residue. Not even enough to halfway damped a paper towel. Butterfly valve was pretty dirty on it's own and is now spotless.
I checked under the battery for any kind of fuel leak by the sending unit. Nothing. Just usual road dust. I have a fuel smell when stopping the car pretty hard so I was curious to solve it.
I am replacing the spark plugs already. I have completed bank 2 side and tested the plugs after installing to check and see if any issues would go away. Nothing.
After clearing codes a few times with each attempt to solve this only codes that persist is p1128 and p1130. Sometimes I see 1126 and 1133 but they don't stick around.
Using the obd2 scanner, a generic one with torque app, I have done as much monitoring as I can. Issues keep changing here and there but some things remain.
I have noticed a lean condition (obviously given the codes) on both banks that doesn't make its mind up. Most recently the lean condition is only present under load and acceleration. I can rev the engine in park doing stability tests up to 4k and it doesn't show up. Highest I see now in park is 4.5 lean and sometimes -7 rich when first started. Just seems sometimes the fuel trim has mood swings and goes from 17 to -20 without doing much.
When I first clear codes i notice it max out lean 25 like it wants to do when doing moderate acceleration. I discovered after doing some of these tests that the car needs to be left alone for 10 mins after clearing the codes upon starting to settle out. Haven't done that yet but also haven't cleared codes since learning it.
O2 sensors also seem wacky. At idle sometimes they look to be doing right. Other times I notice the primaries wanna stay .7 or .1. Might be the slow feedback of the app. Sometimes the primary and secondaries doing the same things, others it just seems like they do whatever. Pretty sure this has to do with the fuel trim being off because of...whatever.
So to recap this insanely long post, its having a starting issue. I ruled out fuel delivery as much as I can by turn key to run pump, turn key off and repeat as quickly as needed to prime fuel.
We can start it if we just killed it. Within 5 mins or so it seems. We can start it from cold start often.
No issues fueling.
No weird noises I can hear.
Cel codes that seem to remain p1128 and p1130.
Used to suffer no other issues now we have performance loss.
Did not smoke test. Found no leaks with using propane.
Did not fuel pressure test.. I am not sure about doing it.
Any ideas what I should focus on other than what I have tried? Anyone with experience in these issues? Going nuts trying to figure it out and not wanting to throw parts at it but about ready to try.
Renos is offline   Reply With Quote
