Old 09-07-2019, 06:45 PM   #1
Long crank starting issue
2002 Boxster S with tiptronic.
So, while I was away from work the wife reported her car started having trouble getting the car started. It went from two or three max turn overs to up to 10 second long cranks.
So upon getting home I have had 2 weeks to deal with this monster and try to learn it. We had a Cel of course and I did as much troubleshooting as i could with hours upon month time of research yet can't figure it out.
It doesn't crank weak. Strong, steady turns till it fires up. Originally we had no drivability issues but I guess overtime or my countless attempts to solve this it now idles a little weak until it jumps to 1100 rpm and settles out quickly.
Rpm band used to be strong and smooth but now we have some hesitation upon acceleration usually around 4k rpm. Even in park it sometimes doesn't allow full throttle. It's not consistant but happens too often to ignore.
It doesn't stall out or die. It only does so clearing the cel when trying to relearn its idle.
So the codes I have seen with this issue so far are:
P0442
P0410
P1411
P1128
P1130
P1126
P1133
P1125
P1132
I discovered the hose off of the aos came loose when inspecting for leaks. It came off of the intake tube side. I connected it back and made sure it was situated better.
I cleaned the MAF sensor as good as anyone could with maf cleaner. Just the cleaner. It has the latest MAF sensor ending in 125.01. MAF readings are 4.5 to 5.5 g/s.
I cleaned the throttle body and intake before and after it. Before it was pretty spotless. Behind it had slight oil residue. Not even enough to halfway damped a paper towel. Butterfly valve was pretty dirty on it's own and is now spotless.
I checked under the battery for any kind of fuel leak by the sending unit. Nothing. Just usual road dust. I have a fuel smell when stopping the car pretty hard so I was curious to solve it.
I am replacing the spark plugs already. I have completed bank 2 side and tested the plugs after installing to check and see if any issues would go away. Nothing.
After clearing codes a few times with each attempt to solve this only codes that persist is p1128 and p1130. Sometimes I see 1126 and 1133 but they don't stick around.
Using the obd2 scanner, a generic one with torque app, I have done as much monitoring as I can. Issues keep changing here and there but some things remain.
I have noticed a lean condition (obviously given the codes) on both banks that doesn't make its mind up. Most recently the lean condition is only present under load and acceleration. I can rev the engine in park doing stability tests up to 4k and it doesn't show up. Highest I see now in park is 4.5 lean and sometimes -7 rich when first started. Just seems sometimes the fuel trim has mood swings and goes from 17 to -20 without doing much.
When I first clear codes i notice it max out lean 25 like it wants to do when doing moderate acceleration. I discovered after doing some of these tests that the car needs to be left alone for 10 mins after clearing the codes upon starting to settle out. Haven't done that yet but also haven't cleared codes since learning it.
O2 sensors also seem wacky. At idle sometimes they look to be doing right. Other times I notice the primaries wanna stay .7 or .1. Might be the slow feedback of the app. Sometimes the primary and secondaries doing the same things, others it just seems like they do whatever. Pretty sure this has to do with the fuel trim being off because of...whatever.
So to recap this insanely long post, its having a starting issue. I ruled out fuel delivery as much as I can by turn key to run pump, turn key off and repeat as quickly as needed to prime fuel.
We can start it if we just killed it. Within 5 mins or so it seems. We can start it from cold start often.
No issues fueling.
No weird noises I can hear.
Cel codes that seem to remain p1128 and p1130.
Used to suffer no other issues now we have performance loss.
Did not smoke test. Found no leaks with using propane.
Did not fuel pressure test.. I am not sure about doing it.
Any ideas what I should focus on other than what I have tried? Anyone with experience in these issues? Going nuts trying to figure it out and not wanting to throw parts at it but about ready to try.
Renos is offline   Reply With Quote
Old 09-07-2019, 09:29 PM   #2
If I am following you correctly you are having a cold start problem.
Most "cold" hard to start issues are due to not having a rich enough fuel air mixture.
Think of carburated engines back in the 50,s and 60's you had to pull a hand choke to give it a richer fuel mixture when starting cold.
So with that in mind I would say you have unmetered air entering the intake. (vacuum leak). or a possible faulty coolant temp. sensor, gauge, or a problem with the wiring related to the coolant temp sensor or gauge.
The ECU reads the coolant temp. as one of the things to determine how long to pulse the fuel injectors on startup.
I would buy a vacuum gauge (15-20 dollars) and do a "PROPER" vacuum test.
Should read 21 inches of vacuum at idle with a steady needle.
Then make sure your coolant temp sensor, gauge and all related wiring are in order.
That would be my starting point.
Old 09-08-2019, 12:10 PM   #3
As an addition to my first reply.
I would hook up a scanner to the ODII with engine cold and check the coolant temp reading. Then if you can start the engine watch the temp as the engine warms up to see if the ECU is getting a correct reading on coolant temp.
Your temp gauge on the dash can be working fine. but the ECU may not be receiving the signal. So you need to verify that the ECU is seeing what it needs to see.
Old 09-08-2019, 01:41 PM   #4
Check the MAF again. Unplug it and let the ECU use the base maps to see if it runs any better. At first it might run like crap, but it should settle down. If it settles down and runs better, then replace the MAF. If it still runs poorly, then I'd check the fuel pump for for proper pressure and flow. Low fuel pressure or volume will make the ECU go crazy trying to get the engine to run properly.
Old 09-08-2019, 01:52 PM   #5
BYprodriver's Avatar
I agree with these steps.
Old 09-09-2019, 09:26 PM   #6
Okay so ran a few more tests on it again.
blue62, I did run it again with obd2 and paid attention to more of the features. I already had as much info as I could up to get benchmarks.
So the temp gauge works for coolant on both obd and the dash gauges. Air temp sensor seems to work too. In 98 to 103 degree weather air temp was saying 130 in intake. Kinda high I think. Stock air filter.
I also wouldn't say it is a cold start issue. More like a hot issue. Cold starts often have the best start for us, it's the ones where we go eat somewhere or in a store and come back is when it struggles.
thstone, we disconnected the maf and seemed to have no change. A pain to start again after clearing codes and nothing better after that.
I have noticed the fuel trims at idle vary between +5 and -8 or -10. At cruise it settles out mostly around 7 to 10 positive. After the spark plug change I gained my performance back mostly. Not much hesitation but when I gas it, it pegs out at 25 lean side.
However I finished changing the driver side plugs. Middle tube, number 3 I think, had oil in the tube. A good bit. Enough it saturated the plug and coil even at connection point. Cleaned them up really good with electric cleaner spray and rags. Put new plug in and promptly ordered a new oem tube with seals just in case the tube is bad.
Engine was cold when I finished and car fired up right away with 2 turn overs, sputtered for a minute about 150 rpm lower till settling back up with the new plugs. Fired it up a few times after it warmed up to 145 degrees and again near 180. It didn't last long...but I noticed something.
When the car struggles to start, and finally fires, all the lights are off on gauge except our top issue, and cel. But the battery light comes back on and cuts off after a second or two.
So I curiously when get it tested as quickly as I could. Battery tested at 12.7 volts and 100% charge and healthy. For some reason I got the car with an h8 battery. Yeah.
So I has alternator tested after. Volts were at 13.8 volts or so and the "alternator tested good however the voltage regulator is failing."
Now I am not being ignorant of getting my fuel pressure tests going but given I go back to work today for a month I havent had the ability to schedule some involving tests like that at any shop... but this brings me to a question again.
How, if at all possible, could the voltage regulator affect the performance of the car with these starting problems?
And how is it the regulator is listed as failing when I have no real symptoms of it? Unless this starting issue is one of them.
Thanks for the help guys.
Old 09-09-2019, 10:41 PM   #7
Now I am not being ignorant of getting my fuel pressure tests going but given I go back to work today for a month i havent had the ability to schedule some involving tests like that at any shop... but this brings me to a question again.
Old 09-10-2019, 04:35 PM   #8
Sorry I was thinking you had a cold start problem.
Every aspect of modern day engine operation and management is via electrical signal. You on your 2002 Boxster and I on my 2000 S don't give the engine fuel or even air. We just push a pedal that is connected to a potentiometer and the ECU does everything else.
So yes a failing voltage regulator could be the root of your problem. or at least a contributing factor.
So I would replace the voltage regulator first as it is a known problem.
If you still have issues.
I would still do a vacuum test with a proper vacuum gauge as that simple test can give you a lot of info on general engine condition. Vacuum leaks can cause a lot of tail chasing.
Also when you replaced you plugs did you check the condition of the coils??? No cracks??
Then:
I would do a fuel pressure and volume test next.
If you have disconnected your battery for any reason you need to recalibrate your throttle. (gas pedal).
If I remember correctly you reconnect the battery.
Turn the key on for 1 full minute ( do not start engine: do not touch the gas pedal).
Turn the key off for at least 10 seconds then start the car and let the computer re-adapt.
Old 09-10-2019, 06:17 PM   #9
If you do a vacuum test you re looking for 18-22 in/hg of vacuum at idle preferably with a steady needle.
I think I stated 21 in/hg of vacuum in an earlier post but the acceptable range is 18-22.
Sorry for any confusion.
Old 09-10-2019, 07:56 PM   #10
Then:
Coil packs look brand new. In fact I noticed they are the updated coils with the thicker mounting holes and longer bolts.
I have a fuel pump coming in and the tube I mentioned had a leak, as well as the voltage regulator. I am still curious about the condition of my aos given I had some oil in the intake but didnt seem like much.
I could go ahead and try for another maf while at it. I will try to have the wife get these tests done given I can't do a thing for a month.
I did replace a fuel cap because of cracked seal and I guess it got my emission leak out but I still also worry about that fuel smell. I wonder if I have a combination of problems going on. Maybe the regeneration valve is failing or crank position sensor. Very confusion with this issue.
All I know is car running lean under acceleration and the crank issue is a major concern. I also noticed since we got the car that I have rpm hunt / bouncing in 4th and 5th gear from 1400 to 2200 rpm. Pretty often too. I would say every second or maybe 1.5 times a second. It jumps up maybe 100 rpm and back. Dunno if this is another contributing symptom but as easy as this car is to work on, it sure is complicated compared to my 2008 mazda mx5.
Old 09-10-2019, 09:16 PM   #11
Yes you could have multiple problems going on. Things like lean under acceleration, RPM hunt, point to a vacuum leak. that would be my first place to look. second would be a lazy (slow) signal from the primary O2 sensors.
My method of diagnosing problems is to start with the simplest most basic things first, proof them out as positive (with no doubts) then move to the next thing on the complexity ladder.
Problems like yours always start by just looking in the engine bay with a flashlight for about a half an hour not even touching anything just looking for things out of place.
Like wiring that could be rubbing against metal or a cracked vacuum hose or?????
Second thing I do is a vacuum test it can tell you a lot if you know what your looking at with the reading and how the needle is acting.
Depending on what my vacuum test tells me that dictates my next step. I don't replace things like MAF sensors or any cam sensors or any sensor unless I know it is faulty. (It could be just faulty wiring attached to it). if there is faulty wiring most wiring problems are due to bad grounds.
So a long winded way of saying simplest things first go step by step up the ladder simplest to most complex.
Most problems are not very far up the ladder.
Old 09-13-2019, 05:55 PM   #12
Well the fuel pump came in and my wife got help putting it in. She didn't do any tests or anything else I asked but she got the pump in and now her issues seem gone. Fuel trim running slightly rich from what I saw and she has one CEL up that is P0430, saying a catalytic converter is failing I assume.
So one headache down, another one to go.
Thank you guys very much for the help and advice. I would have done it myself if home and able but sadly work requires me away for a month at a time.
