Old 09-09-2019, 08:44 AM   #1
Bald Eagle's Avatar
Cost to Replace aos?
I'm thinking of proactively replacing the aos before winter storage. Any ideas about the cost from inde?
Larry (the bald eagle)
Old 09-12-2019, 01:42 PM   #2
Should be less then 2 hours labor + part.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 09-12-2019, 02:20 PM   #3
Need For Speed
KRAM36's Avatar
I can change the AOS on my 03 S in 30 min easily. I would not buy one and then store the car. Buy one when you pull it out of storage or wait for it to fail.
2003 Boxster S
Old 09-12-2019, 03:13 PM   #4
AOS is just around $120 and if u have a little knowledged to wrench, just replace it by yourself. And yes probably replace it later after winter.
ndfrigi is offline   Reply With Quote
Old 09-15-2019, 08:14 AM   #5
If it aint broke, don't fix it. If it fails--starts to smoke it won't damage anything if you promptly get it fixed. An Indie Porsche (german car shop) could probably get you a pretty close estimate. It's do able, but tough for fat old guys with ham hands, like me. :ah:
2001 Boxster
2007 Toyota Highlander
Old 09-15-2019, 10:09 AM   #6
Ciao's Avatar
Unless AOS is damaged, proactively changing oil, filter, and perhaps fuel filter, pollen filter, and air filter would be more effective in periodic maintenance.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 09-15-2019, 12:21 PM   #7
'03 and '04 sure is a much easier job than the earlier cars!
Old 09-15-2019, 12:54 PM   #8
Bald Eagle's Avatar
Thanks for your thoughts. You gave an old, fat, bald guy with thick fingers some options to consider.
Old 09-15-2019, 06:12 PM   #9
Take off the right rear wheel and it is a 30 min job!
Vtx531 is offline   Reply With Quote
