Old 09-09-2019, 08:44 AM   #1
Bald Eagle's Avatar
Cost to Replace aos?
I'm thinking of proactively replacing the aos before winter storage. Any ideas about the cost from inde?
Larry (the bald eagle)
Bald Eagle is online now   Reply With Quote
Old 09-12-2019, 01:42 PM   #2
Should be less then 2 hours labor + part.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 09-12-2019, 02:20 PM   #3
Need For Speed
KRAM36's Avatar
I can change the AOS on my 03 S in 30 min easily. I would not buy one and then store the car. Buy one when you pull it out of storage or wait for it to fail.
2003 Boxster S
Old 09-12-2019, 03:13 PM   #4
AOS is just around $120 and if u have a little knowledged to wrench, just replace it by yourself. And yes probably replace it later after winter.
ndfrigi is offline   Reply With Quote
Old 09-15-2019, 08:14 AM   #5
If it aint broke, don't fix it. If it fails--starts to smoke it won't damage anything if you promptly get it fixed. An Indie Porsche (german car shop) could probably get you a pretty close estimate. It's do able, but tough for fat old guys with ham hands, like me. :ah:
2001 Boxster
2007 Toyota Highlander
Old 09-15-2019, 10:09 AM   #6
Ciao's Avatar
Unless AOS is damaged, proactively changing oil, filter, and perhaps fuel filter, pollen filter, and air filter would be more effective in periodic maintenance.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 09-15-2019, 12:21 PM   #7
'03 and '04 sure is a much easier job than the earlier cars!
dghii is online now   Reply With Quote
Old 09-15-2019, 12:54 PM   #8
Bald Eagle's Avatar
Thanks for your thoughts. You gave an old, fat, bald guy with thick fingers some options to consider.
Old 09-15-2019, 06:12 PM   #9
Take off the right rear wheel and it is a 30 min job!
Vtx531 is offline   Reply With Quote
