09-03-2019, 09:17 AM
Front Windshield trim/moulding replace??
Q for the group. The trim around the front windshield is worn and cracked. Is it possible to remove and replace without taking out the windshield?
2001 986 S.
09-03-2019, 09:46 AM
Who's askin'?
You have trim AROUND the windshield?
09-03-2019, 10:08 AM
1998 Boxster Silver/Red
I have trim around the my windshield. Every vehicle ever I've owned has had trim.
Or... is it molding... weatherstripping. Nah, it's a Porsche. Trim.
1998 Porsche Boxster
09-03-2019, 10:10 AM
Will there be cake?
2001 986 S.
I've had my windshield replaced twice for my 986 S cars. Once they used a stock rubber gasket...used but in perfect condition. I recall a new stock trim was unreasonably expensive. On the other car they used an aftermarket which looks different...all black rubber.
They have to take out the windshield as I remember. it wraps around and is glued in and I heard that the "s" trim is different.
09-03-2019, 11:33 AM
The S trim is different, it is two pieces, one is black plastic and one is titanium gray plastic. It is glued on. When I had my windshield replaced I had to buy the two pieces from a Porsche dealer for my glass guy to glue to the windshield before he could install it. Otherwise he would have used some generic black trim he had. He said the old trim on my windshield couldn't be reused, it was a bit tired after 15 years so I didn't question it and bought new.
09-07-2019, 10:34 AM
Well, yes, kinda...
I did replace the trim on my '02 S so that qualifies as proof that it can be done but my oh my what a PITA! Here's a link to my web site that shows the adventures that I had with this project. https://rx19jones.wixsite.com/projectboxster/projectboxster-3
cheers- dj
(not sure why this photo posted upside down...)
2002 Boxster S Orient Red Metallic / Graphite Gray
https://rx19jones.wixsite.com/a-986-s
11-22-2019, 09:48 AM
A 986 S,
Thanks for your walk-through in doing this! Where did you buy the trim and would you happen to know the part number?
11-26-2019, 08:31 AM
cheers- dj
Thanks for that (very nice DIY site BTW). I’m convinced that a strip and paint in place is the most reasonable fix now as long as the trim is in good shape structurally.
'01 986S
‘07 GT3
'80 911SC Weissach Edition (Sold)
‘11 958 S
https://dergarage.com
09-07-2019, 11:10 AM
WALDMEISTER
Noice!
That project is on my bucket list, too. The new chrome trim has been sitting here for years, now.
09-07-2019, 01:50 PM
My 02S has the same problem , the black portion is in good shape but the titanium color insert is crumbling due to sun exposure . There must be something out there even if it is black in color that can be inserted . It is on my list to research and replace .
12-28-2023, 09:59 AM
Very old thread but has anyone else accomplished this task. My trim is broken in several spots and needs to be replaced. Not sure if I should try or just get someone to remove the windshield.
Supercar dreams on dollar menu budget
12-30-2023, 06:26 AM
If repairing/repainting the trim in place isn't an option, I don't see a downside of trying to remove the old trim before taking the drastic step of removing the windshield.
Assuming that you have the two-piece S trim, the first step would be to remove the black rubber seal. You may be able to clean and reuse that part. Use a hair dryer or heat gun to soften the glue and gently pry away the old trim with forceps or needle nose plyers. Be careful and take your time. It probably won't be quick and easy, but you should be able to remove the old trim.
Of course, if it doesn't work out you still have the option of removing the windshield and installing the new trim when reinstalling it.
Good luck and let us know how your project goes.
dj
12-30-2023, 07:25 AM
Guess I will give it a try. Have an S model and already have the metal trim piece. The rubber piece is good but noticed the metal can’t be saved and won’t hold the rubber in place anymore.
07-14-2025, 07:02 PM
Great thread. And big props to the fellow that put together a DIY on his website. I am preparing my 986S Guards Red for sale.
As of July 2025, the S metallic molding is discontinued, so I am using the 2003/04 version.
I just completed the Brembos calipers restoration and thought this windshield trim will be simple and satisfying - just like the blister did... WRONG. Pain in the arse.
I will add some photos during the removal of the trim using heat.
For reinstallation I am considering to remove the bottom lip of the molding so that the trim can be glued in place. It will speed installation and lessen chance of damage.
07-16-2025, 08:41 AM
Last time I checked, Pelican had the gasket/rubber trim for the windshields for a reasonable price. I'd never be happy leaving the trim up to a window installer unless the guaranteed it would match the original.
Years ago, a window installer on a different car used a generic (non-matching) and it bothered me until the day I sold it.....lesson learned.
98' Boxster
