Old 08-18-2019, 03:46 AM   #1
1998 Boxster Silver/Red
Dead battery - car tow
I've been reading this morning and ran accross some threads about towing the 986. I found that if the battery is completely dead... the Tiptronic transmission won't be operable. If this is correct...
I suppose a tow truck driver could juice up the dead battery/install a temp. Absent that... how would you move the shift lever to neutral? Is there a hidden switch? A panel to remove to access the/a switch?
Also... Focke had a .pdf upon his site that was published by AAA on how to properly tow thge 986. That link is dead. Any special tips for a tow truck driver in the event a tow is necessary?
Thank you.
1998 Porsche Boxster
Old 08-18-2019, 06:24 AM   #2
A Porsche Guy
1PorscheBoxster986's Avatar
I would assume that the Boxster will have a shift lock in the tiptronic version. It might not be blatantly displayed like newer cars. My guess is that it is located underneath the boot of the shifter knob. This is the diagram for the automatic shifter. Let's find out where is shift lock.
1PorscheBoxster986 is offline   Reply With Quote
Old 08-18-2019, 06:41 AM   #3
Porsche "Purist"
Paul's Avatar
Owners manual says to use wheel lifts and that the car can only be towed with all 4 wheels off the ground.
1987 924S. 2002 996TT. PST-2
Old 08-18-2019, 07:02 AM   #4
Thank you, both.
OK. Gotta find that shift lock.
And... the wheel lifts... thank you.
Old 08-20-2019, 12:05 PM   #5
Have the tow truck jumpstart the car and then drive it home or have it transported on a flat bed truck.
2001 Boxster
2007 Toyota Highlander
Old 08-20-2019, 12:17 PM   #6
Thank you, Brian. Many of your responses leave my inner dialogue telling me, "Jim, keep the **************** simple".
Old 08-20-2019, 12:32 PM   #7
Hey Jim,
Just keep it simple... get this.
"Cool Prius!"
- Nobody
