Old 06-30-2019, 10:01 AM   #1
Window question
So I just took my Boxster out of storage and the power windows are not working. They do make the adjustment when I open the door but the switches do not work. Fuse D1 seems to be OK. Any ideas?
bkiersz is offline   Reply With Quote
Old 07-01-2019, 05:42 AM   #2
Can you raise and lower them using the key in the door? Do they move correctly when the convertible top is actuated?
Maybe you've got corroded switch contacts? I'd try to hot-wire the windows at the switch location to see if I could get them to move.
Boleador is offline   Reply With Quote
Old 07-01-2019, 07:48 AM   #3
piper6909's Avatar
Do your locks and trunk/frunk releases work? If not, you most likely have an immobilizer problem. It probably got wet. That was the issue with mine.
