Old 06-19-2019, 05:37 PM   #1
Tire question...
I just bought a 2004 Boxster and the tires that where installed are:
- Front - 205/50 ZR 17 93W M S (Continental)
- Rear - 255/40 ZR 17 94W M S (Continental)
Is it normal to have different sidewall heights?
besturgeon is offline   Reply With Quote
Old 06-19-2019, 05:43 PM   #2
Yes, that is normal. Those are the stock tire sizes.
It is common for many owners to install a 225/45 on the front to reduce the stagger between the front and rear tires to reduce understeer.
Old 06-19-2019, 05:46 PM   #3
Racer Boy
Racer Boy's Avatar
Yep, those are the stock sizes. Many sports cars have different sized tires front and rear.
Old 06-19-2019, 06:21 PM   #4
And in nominal terms 50% of the 205 mm section width is a 102.5 mm sidewall and 40% of 255 mm is a 102.0 mm sidewall. 45% of 225 mm is 101.25 mm. I say nominal because every tire manufacturer's sizes are a little different and the width of the rim the tire is mounted on also affects section width.
Old 06-19-2019, 07:16 PM   #5
On the slippery slope
JayG's Avatar
Many that track or AX their cars go with the wider (225) front tire. For DD/street, the 205's are fine
2004 996 Targa Tip
Instructor - San Diego region
