Old 06-17-2019, 02:06 PM   #1
New brake switch - PSM & ABS ON
Hello folks!
For few months i was noticing that the rear lights were not lighting immediately when i was pressing the brake pedal, and that sometimes, after hard braking the PSM and ABS Failure was coming on.
So i decided to install a new brake switch. The procedure is fairly simple and i did it all fine. Now the sensitivity of the brake lights are perfect. But now the PSM and ABS failure lights come on everytime i start the car.
If i shut the car down and restart, the come off again.
Rear lights working good. PSM and ABS work also good (even with the warning lights ON)
What did i do wrong ?
Thanks as always.
Lacostas is offline   Reply With Quote
Old 06-17-2019, 03:09 PM   #2
Jay
I think the issue is unrelated to brake light switch. I also changed brake light switch and I believe it’s sole purpose is to illuminate brake light. Since you were getting these lights earlier also, the problem is elsewhere.
Jay
jay2015 is offline   Reply With Quote
