Old 05-17-2019, 12:37 PM   #1
sfkjeld's Avatar
Diagnosing weird sound from engine bay
The sound is a low level clatter. Audible when at idle and low rpm in first gear. I think it only becomes inaudible because it is drowned out by normal engine sounds. It occurs to me now that it could be a failing water pump bearing. Does this seem likely if there are no coolant leaks? My first theory was a chain tensioner..... do they make a noise if failing?
sfkjeld is offline   Reply With Quote
Old 05-17-2019, 12:54 PM   #2
piper6909's Avatar
Heat shield?
Manual or Tip? If it's manual, when you're in 1st, obviously your clutch would be depressed. If that's the case, I'd also suspect the throwout bearing. Try pressing and releasing the clutch and see if the noise changes.
Old 05-17-2019, 01:03 PM   #3
sfkjeld's Avatar
Heat shield?
Possible I guess, but the sound doesn’t change with rpm as I think it would if it were a vibration. It sounds more like marbles in a coffee can, but not very loud or tinny sounding. I’d love to hear if these water pumps fail like this. Or chain tensioners. I think I had an old Alfa with a bad water pump that may have sounded vaguely like this. But it leaked coolant. Thank you for the suggestion.
Old 05-17-2019, 01:06 PM   #4
sfkjeld's Avatar
Heat shield?
It is a manual. The clutch has no bearing so to speak, on the sound. Sounds exactly the same whether in gear, clutch in or out, or neutral. Thank you for the thought tho. I appreciate it. Cheers.
Old 05-17-2019, 01:13 PM   #5
piper6909's Avatar
Ah, I was under the impression it only did it in 1st.
Old 05-17-2019, 05:03 PM   #6
"It sounds more like marbles in a coffee can" ... IMS
Joe K. Peachtree City GA
2001 986 Boxster S, Silver with black interior.
blueflames is offline   Reply With Quote
Old 05-17-2019, 05:40 PM   #7
piper6909's Avatar
Has this happened to you? It would be awesome if the IMS gave warning signs like that. All I've heard that it goes with no warning.
What I've read is that maybe it makes a strange sound for a sec or two then kaboom!
Old 05-17-2019, 07:48 PM   #8
sfkjeld's Avatar
That’s my understanding. Anyway, I had an LN IMS bearing installed 2 years ago.
I so appreciate all ideas tho, thank you.
Old 05-18-2019, 05:14 AM   #9
Are you diagnosing this noise from the driver's seat? If so then you need to get out and check from the back. My first guess would be something with the exhaust. Heat shields are notorious for coming loose.
Woody
Old 05-18-2019, 08:28 AM   #10
sfkjeld's Avatar
thanks. I does not seem tied to vibration tho. But yeah, I going to have put on a rack next week.
Old 05-22-2019, 08:01 PM   #11
I also have this problem. The sound goes away at 1100 rpm. I thought it was because of the bad motor mount. Changed the mount, sound persist, but dang the handling is better. While changing the motor mount I am sure i found the real cause. The power steering. The slash tray was soaked wil ps fluid. The top of the motor is wet with ps fluid. I did not have the time to pull out the pump because it requires moving the ac compressor, not a big deal but I'm not up to it right now, maybe later this week. Car is a 2001 tiptronic with a swapped 3.2.
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
Old 05-22-2019, 08:22 PM   #12
any update of your issue?
if still trying to find the sound, try to remove the engine cover access behind the seats and then find a plastic tube to use like a stethoscope while engine running. Try to listen to your water pump, various pulleys, AC compressor and alternator.
I eliminated several sounds from water pump, 2 pulleys and engine mount and now last one need to fix is my compressor but no time yet to do it. Currently I have around 107k on ODO.
ndfrigi is offline   Reply With Quote
Old 05-23-2019, 02:00 PM   #13
Xpit77's Avatar
As crazy as this sounds. Check the heat shields on the cats.They can rattle at certain RPM.Been there.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 05-23-2019, 02:46 PM   #14
1998 Boxster Silver/Red
This is about his car, not my first wife.
1998 Porsche Boxster
Old 05-24-2019, 01:53 AM   #15
sfkjeld's Avatar
You got it. Water pump. And thank you for the excellent pics. I decided I didn’t want to mess with bleeding the coolant system tho. My first estimate was $1000 to replace the pump. A bit shocking.
Old 05-24-2019, 04:18 AM   #16
piper6909's Avatar
Thanks for posting the solution.
What's involved in bleeding the coolant system? Is difficult?
Old 05-24-2019, 04:45 AM   #17
When I replaced my WP I raised the rear of the car as high as my stands would allow... opened the bleeder valve... added coolant... revved... added more coolant... revved... repeat until the coolant level is to specs.
I then left the valve open for a few more days, drove around, and keeping an eye on the coolant level. Closed the valve and all has been good since.
You getting ready to replace your WP?
Old 05-24-2019, 04:51 AM   #18
piper6909's Avatar
Not planning on it anytime soon, but you never know. I was curious what's involved in it for when I have to. I want get as much info on these cars as I can.
Old 05-24-2019, 07:36 AM   #19
2003 S, Arctic Silver, M6
paulofto's Avatar
Just my 2 cents worth. If you get your hands on a Uview Airlift or equivalent, the vacuum of the coolant linesand refill of coolant is a piece of cake. I got mine from Princess Auto here in Canada for about $40.00. Makes the whole process very easy. You do need access to a compressor to run the device so maybe not for everyone.
Old 05-24-2019, 05:09 PM   #20
If you’re local I can do it for $250 on labor. hehehe
sfkjeld and piper6909, not really hard to replace it and just follow what starter986 instruction on bleeding. That is how I did on bleeding.
