Old 05-22-2019, 08:01 PM   #11
Turbodad
I also have this problem. The sound goes away at 1100 rpm. I thought it was because of the bad motor mount. Changed the mount, sound persist, but dang the handling is better. While changing the motor mount I am sure i found the real cause. The power steering. The slash tray was soaked wil ps fluid. The top of the motor is wet with ps fluid. I did not have the time to pull out the pump because it requires moving the ac compressor, not a big deal but I'm not up to it right now, maybe later this week. Car is a 2001 tiptronic with a swapped 3.2.
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
