Old 05-21-2019, 09:55 AM   #1
sfkjeld's Avatar
Engine swap cost
I may be purchasing a rebuilt motor for my 2000 base Boxster. The rebuild comes with a new water pump and oil cooler, the rest has to be transferred from old to new + fluids. What should I expect to pay to install this motor? Was just given a rough estimate of $2500. Does that seem in the ballpark?
sfkjeld is offline   Reply With Quote
Old 05-21-2019, 12:00 PM   #2
seningen's Avatar
I think this depends on what you do while you're in there. Clutch/flywheel.
THSTONE has this does this all the time -- :-)
The fluids/AC recharge will cost you ~$500 at a shop,
so $2500 is probably not unreasonable for a California shop.
Mike
mike@lonestarrpm.com
Old 05-22-2019, 07:49 PM   #3
Artist, 986S tinkerer
NewArt's Avatar
Normally, the a/c stays with the car so shouldn’t need to be recharged. I have just finished swapping all the peripherals onto my new engine (you can see the process on my YouTube channel). It is time consuming and requires a number of new seals and bolts, as well as the fluids.
Old 05-22-2019, 09:15 PM   #4
I am on Engine #5 so I've had this done four times.
For a straight engine swap plus consumables, the cost really should be well less than $2,000. $2500 is certainly on the high side.
Old 05-23-2019, 10:09 AM   #5
I assume this does not include the cost of installation.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
