Old 05-13-2019, 02:45 PM   #21
jaykay's Avatar
I think the problem comes up when you get to a certain number of cycles (brake changes) on a set of aluminum alloy tapped holes. If you are rushing this at the track and working with dirty threads then the probability goes up.
986 00S
Old 05-13-2019, 04:14 PM   #22
piper6909's Avatar
Galvanic corrosion. Steel bolts in Aluminum. That's what we're dealing with. If you can limit contact with oxygen you can prevent it. I've had good luck with anti-seize, and others like to use oil-based paint. Many people swear by Tef-Gel. I've never tried it, but it's made specifically for applications like this.
piper6909 is online now   Reply With Quote
