Old 04-08-2019, 05:15 PM   #1
Trick to cleaning license plate
I didn't have much luck searching Google on tips to cleaning the license plate from exhaust carbon. Granted....99% of the cars on the road don't have a centered exhaust output.
Soaked it in water for an hour while I washed the car, dishwasher detergent (I used Joy), and a steel wool pad. See for yourself!
And yes it's a lot of carbon - it burns oil and I hadn't cleaned it in a very long time.
Before and After
Old 04-08-2019, 05:34 PM   #2
Need For Speed
KRAM36's Avatar
Nice job on getting the plate clean.
Does your car blow a lot of smoke out when you start it after it's been sitting for a bit?
2003 Boxster S
Old 04-08-2019, 05:44 PM   #3
Just burns it as the car runs. It wasn't too bad (1 quart per 5000 miles) until the AOS blew at around 85k miles. Ever since it's been 5+ quarts per 5000 miles. But car still runs great aside from that...now at 115k.
Old 04-08-2019, 06:03 PM   #4
Need For Speed
KRAM36's Avatar
I'd get the AOS replaced asap.
2003 Boxster S
Old 04-08-2019, 06:25 PM   #5
Haha no I did replace the AOS at 85k when it blew. Then again immediately because I thought it was a bad AOS with the oil consumption. It consumed the oil despite 2 new AOS's.
Old 04-08-2019, 07:37 PM   #6
1998 Boxster Owner
And the IMS bearing
Benitom is offline   Reply With Quote
Old 04-08-2019, 11:25 PM   #7
Need For Speed
KRAM36's Avatar
Originally Posted by Benitom View Post
And the IMS bearing
2003 Boxster S
Old 04-09-2019, 08:04 AM   #8
lkchris's Avatar
Wax it should only need water next time
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 04-09-2019, 08:19 AM   #9
you sure you didn't damage motor when AOS blew? that kind of an increase in oil consumption points to much more serious issues.
Old 04-09-2019, 12:28 PM   #10
Hard to say but I did shut it down immediately when it blew. And ran for just a couple seconds at home. I did compression and leak down tests months later and the numbers were fine (don't recall actual numbers).
I don't worry too much about it as I'm not going to do an engine rebuild/repair that costs half or 3/4 of the value of the car.
Old 04-09-2019, 02:47 PM   #11
I seem to recall one of the pros (maybe Jake) mentioning a while back that he was seeing a lot of new stock AOSs crap right out of the box.
clickman is online now   Reply With Quote
