03-29-2019, 06:00 PM
Engine Overheated, Coolant Leak?
Noticed the engine temp was at the max and a red light next to the temp was on.
Oil light flashed a couple times.
Continued driving for about 5 minutes / 3 miles to my destinations.
Got out of the car, and the engine was giving a slight whistle.
Noticed this leak right away. It kept leaking for a long time.
Second photo is when I opened the trunk a couple hours later.
Is this a coolant leak? Should I be worried about anything else -- engine damage, water pump?
A few minutes before I noticed the engine temp, I stalled twice in a couple seconds at a red light -- I just bought this car a few weeks ago and still learning to drive a manual. That was my only stall on this 40 minute car ride. Could stalling & restarting the engine right away have caused the issue, or is that a coincidence?
03-29-2019, 06:30 PM
1997 Tip, 2018 Macan
Don't start or drive it until a mechanic looks at it. You have a potentially very serious problem. That is oil and coolant mixed together. Search 'intermix' when you are ready for some sobering possibilities.
03-29-2019, 07:05 PM
Stick a fork in that one, it is done...……….
03-29-2019, 07:28 PM
Damn, just bought the car 3 weeks ago. Skipped ppi as the owner was on top of maintenance.
Googling now. Anything I could've done to have prevented it?
03-30-2019, 03:06 AM
I may have to wait till monday to get hold of a mechanic/specialist.
Do I have any hope that a 'exhaust gas' test as mentioned by JFP here will succeed? Or do photos point to a definite engine issue?
Engine Diagnostics - Intermix
03-30-2019, 04:49 AM
Originally Posted by pizzafan
... Anything I could've done to have prevented it?
Engine temp at max and Red light means pull over and STOP driving. There are several things that could have gone wrong initially, but to continue driving for even 5 minutes can make a lot more things go wrong.
Stalling and restarting is not and underlying cause. There is no way for us to diagnose exactly what the initial cause was or what further damage could have been done by simply looking at the pictures.
We could talk about cracked heads, oil coolers, rods bolts, and IMS bearings, but I don't think it would be helpful at this point. Judging from what you have written, I'm guessing that you have not worked on cars much, so advice on taking things apart probably is not going to be of any use. I'd recommend that you do not try to start the car and have it towed to a mechanic with some Porsche experience to evaluate if the engine is repairable at an affordable price.
...sorry for your loss.
03-30-2019, 06:58 AM
I did the same thing, we both bought the car with a cracked head which I should have been smart enough to figure out. Well it caused me to learn how to remove the engine and many other things about the car very quickly. I love the car and have done lots of things to it. It was a little daunting to tackle the project at 60 but I did it and many other projects to it. I now consider myself very knowledgeable about the car. It now has 130K on it.
03-30-2019, 07:16 AM
Sorry for you loss. Not a good way to start an ownership experience.
There is a guy over on Pelican with an 04 base Boxster who mistakenly bought an 01 2.7 engine thinking it would work in his 04. It won't, so he might be grateful to find someone interested in relieving him of his mistake.
Engine swap. 2001 to 2004 2.7 - Pelican Parts Forums
Oops - I see you have an 02 S. Never mind. I'll leave the link in case someone else is looking for a base engine.
1989 928 S4 5 spd - black
03-30-2019, 07:59 AM
got you beat, I was 66 when I did mine in the carport in winter of '17. Same sort of thing, tho mine didn't come down with intermix--just got really hot and I didn't want to trust it.
To the OP, sorry your engine is really and truly ruined. All sorts of bad things happen when it over heats that bad. Rings lose temper and don't seal, valve seals leak, things get warped.
You have some hard choices to make. :ah::ah:
2001 Boxster
2007 Toyota Highlander
03-30-2019, 08:48 AM
Thanks, bringing it to a mechanic on monday or tuesday, and will let them diagnosis & give me my options.
04-01-2019, 09:06 AM
Will there be cake?
Is this an S or Base boxster?, year, mileage, options?
I bet you have a cracked head, and definite intermix. Been there twice now.
Engine is toast and so are all the hoses, radiators, etc. etc unless you clean this out quickly.
you need to decide if you are keeping the car and swapping out the engine or shopping for something else. (do all the cleaning immediately or you have more problems) My humble advice is unless you are wrenching this yourself, you are far, far outside what it is worth. If you don't clean up the intermix, the rest of your shell is diminished in salvage price also.
Sorry for your loss.
04-01-2019, 09:11 AM
Skipped ppi...
That says it all.
04-01-2019, 10:38 AM
tonythetiger, just curious why you ask whether it's a base or an S? Is one more susceptible than the other to this kind of failure?
04-01-2019, 10:55 AM
Just run some granular Tide laundry detergent thru it several times till clean and it will be fine. Mine has been running for 25k since repairing with no problems and good cooling. The cracked head is another thing. It was a good learning experience and took the opportunity to replace some wear items while out but wish I had done a few more.
Hoffman machine said cracked head was due to core shift. Just a little more aluminum would have eliminated the problems. Thanks Porsche
04-01-2019, 11:12 AM
Will there be cake?
both intemix issues I saw were "S" and both times passenger side heads, but I also asked if it was an S because there are many parts on the S that have value, such as the rads, brakes and stuff. Makes cleaning up important to save any money or fix.
04-01-2019, 11:29 AM
Will there be cake?
Hoffman repaired your heads? I considered that route and noodled that I still had an old engine with old rods, pistons, etc. and decided I would ditch the car. The second one was presented to me with intermix and I parted it.
It all worked out for you, huh? Nice, Len was really cool and talked to me about options.
BTW, agreed, laundry detergents, and massive flushing...takes several days but you can make a weekend of it.
Pizzafan, here is a resource for what likely went wrong...you can review hoffman automotive machine, do the google and flat6innovations website as well for some good info.
04-01-2019, 11:56 AM
What is "core s hift?"
2001 Boxster
04-02-2019, 05:23 AM
Core shift of the mold when manufacturing the head. Len Hoffman is fantastic. I think it was around $700 but depends on the problem. i have put TONS of money in this car but I luv it. At 130k it still runs fantastic but I know that day will come for a whole lot of money to be spent, it's 3.6 time.
04-04-2019, 04:22 PM
Will there be cake?
Did you find a root cause or outcome yet?
04-05-2019, 04:21 AM
Rennzenn
Looks like what happened to my 996...which was a cracked head. Len Hoffman repaired my heads and did a stage 1 porting on them. Fortunately, the bottom end was fine. I did all of the work with the generous help of a few friends and the bill came to around 6K. This included the heads, new clutch/FW, AOS, lifter rebuild, injector rebuild, gasket kit, ARP head studs, oil, coolant, and other "while you are in there" items. A year later/20K miles later she's running great.
Rennzenn
Jfro@rennzenn.com
